By
atcronin
Florin Socol
Last night, around 22:30 CET I got a screen notice that there is a new update avalable for my TV. I coose to install it and after some time I got a new notfication that the update will finish istalling on next restart. So I restarted the TV using the remote, but it only displays the LG logo!
On local Romanian LG facebook page, another guy shared the same expirience last night
I opened a service request at LG suport service. Waiting for the tech to call me.
16 answers to this question
