Incessant "open input list" on power-up -- 65UB9500
Has anyone in the community had issues with the incessant "Open Input List" pop-up on the bottom of the screen on power-up?
To reproduce:
  - You need the TV (65UB9500) connected to a single HDMI source via an AV receiver
  - Power on the source selected on the AV receiver
  - Power on the receiver, with the correct input selected
  - Power on the TV
The TV will go through multiple handshaking "glitches" (video goes on, then off, then back on) while the audio is playing.  At the end, the video will be showing.  Twenty seconds later "Open input list" appears, saying that there's no video signal (except there is...)
I've tried disabling SIMPLINK, HDMI control on the receiver side, everything.
What seems to trigger the issue isn't so much the presence of video, but if the TV sees a source over HDMI where it can't identify the source.  If you bring up the "input switcher" app -- you can get a description of the attached source over HDMI.  The device, if it isn't populating the list, confuses the TV.
Has anyone seen this before or addressed it?
6 answers to this question
I get this message all the time. Whenever I turn on my computer, then the TV (55UB8500) about 5 seconds later I get the "Open input list?" message. Drives me nuts. I tried turning on my TV first, then the PC, but it does not help. Same problem with my Playstation. If anyone knows how to fix this I'd love to hear it.
Unfortunately, there is no fix -- especially if you have the device connected through an AV Receiver.  I ended up having to swap out the unit for a UF model instead of a UB model.
This is also driving me nuts! I have contacted LG Support three times and each time they say that the issue is too complicated and to call a different number (once they suggested disabling SIMPLINK, but it was already disabled). I don't believe the "Open Input List" box showed up like this in the beginning - before any firmware updates. This TV (65UB9500) is incredibly slow and I've been pretty unhappy with this purchase. Would anyone have a suggestion on how to revert to the factory-installed firmware? Thanks.
I have the exact same issue, that is extremely annoying!
They could at least create an option to disable that stupid message or remove it all together  :angry:
I know this is an old thread but I thought I’d share how I fixed it. This was driving me nuts also but I got my “open input list?” pop up to go away by turning ON Simplink.  The pop ups went away and some of my devices automatically turn on when I switch to them.
    • By OhmorrowSouthWales
      Consortium’s Real-World Labs in Anchorage and Fairbanks
      Aim to Optimize Heat Pump Performance in Tundra Conditions
      ANCHORAGE, Alaska, Dec. 12, 2024 — The Consortium for Advanced Heat Pump Research, the groundbreaking partnership between LG and the University of Alaska Anchorage (UAA), has opened state-of-the-art, real-world-simulated labs to conduct comprehensive studies on cold-climate heat pump HVAC solutions.
      LG and university researchers will conduct studies in two dedicated cold climate heat pump labs located in Anchorage and Fairbanks. These facilities are configured to replicate home environments, enabling a realistic and practical approach to heat pump research. The labs will utilize a variety of LG’s cutting-edge HVAC solutions, including both ducted and duct-free indoor and outdoor units, to assist in the research.
      The work of the Consortium for Advanced Heat Pump Research exemplifies Alaska Governor Mike Dunleavy’s focus on nurturing impactful technology initiatives built on strong public-private partnerships. “Together, researchers from the University of Alaska Anchorage and global innovator LG Electronics are advancing the state of the art in heat pump technology,” the governor said. “These advanced research labs show how new business and investment in Alaska can have a major impact on our nation and the world.”
      “Heat pump technology is integral to HVAC-related decarbonization efforts, and the research conducted at these new labs will help to further drive progress,” said Chris Ahn, president of LG Eco Solutions USA. “This research into advancing progress in heat pump system technology supports the promotion of clean energy advances that are among the primary targets for IRA (Inflation Reduction Act) funding in most states, including those in colder climates.”
      The Cold Climate Heat Pump Labs in Alaska will leverage LG’s cutting-edge heat pump technology to deliver region-specific comfort solutions designed to reduce dependence on fossil-fuel secondary heating sources. In fact, the Anchorage and Fairbanks labs are committed to further enhancing the capabilities of air-source heat pumps to be the primary source of heating in ambient temperatures as low as -40 degrees Fahrenheit.
      The LG Residential Cold Climate Heat Pump, which was just awarded the 2025 AHR Innovation Award in the Sustainable Solutions category, underscores the company’s ongoing research and development efforts for products under cold conditions.
      “The research conducted between LG Electronics and UAA will provide ground-breaking insight into heat pump technology to create the best performing, most energy efficient solutions possible,” said University of Alaska Anchorage Chancellor Sean Parnell. “We’re proud to bring this cornerstone of our university to the HVAC market with LG.”
      The between LG and UAA, launched a year ago, brings together LG experts, university researchers, local industry and government agencies to drive market transformation through research on heat pump technology and electrification. The new labs christened this week will showcase the breadth of LG’s HVAC product capabilities in heating and cooling, setting new benchmarks for energy efficiency.
      The Alaska consortium is an integral component of LG’s extensive network of heat pump research partnerships across Korea, Europe and China. These collaborations collectively form the Global Consortium for Advanced Heat Pump Research, demonstrating LG’s dedication to broadening its research and development programs. LG’s strategic formation of the consortiums has resulted in a robust, global R&D infrastructure, and the wide-reaching approach equips LG with the capability to develop technologies that cater to the unique climatic and housing conditions regionally.
      For more information about LG’s U.S. air conditioning business, visit
      LG SIGNATURE OLED T and CineBeam Q Honored
      for Their Groundbreaking Innovation and Unprecedented Design
      ENGLEWOOD CLIFFS, N.J., Nov. 1, 2024 — This week, TIME revealed its annual list of the Best Inventions, naming the
      link hidden, please login to view to the list which features 200 groundbreaking innovations changing the world. Debuted at CES 2024, the LG SIGNATURE OLED T is the world’s first consumer transparent TV with transparent 4K OLED screen and LG’s wireless video and audio transmission technology, transforming users’ viewing experience with unprecedented freedom. Additionally, the  received a special mention for its sleek design, light form factor and performance. TIME’s Best Inventions of 2024 list is compiled by nominations from TIME’s editors and correspondents around the world, and through an online application process, evaluating a variety of industries and sectors such as consumer electronics, education, sustainability and robotics. Each submission is evaluated on several key factors, including impact, reach, creativity and effectiveness. See the full list here:
      Of this year’s list, TIME’s editors write: “The result is a list of 200 groundbreaking inventions (and 50 special mention inventions)—including the world’s largest computer chip, a humanoid robot joining the workforce, and a bioluminescent houseplant—that are changing how we live, work, play, and think about what’s possible.”
      Revolutionizing the world of home entertainment, the LG SIGNATURE OLED T transforms how we experience screens in our homes. This groundbreaking innovation not only delivers stunning visuals but also features a breathtaking transparent display that seamlessly blends into your environment when not in use. With its ultra-slim design, the LG SIGNATURE OLED T transforms into an elegant piece of art, enhancing any room’s aesthetic. Advanced wireless technology enables the transmission of 4K video and audio without the clutter of cables, offering a truly immersive viewing experience. The TV boasts exceptional picture quality, showcasing vibrant colors and deep contrasts, setting a new standard in home entertainment. With the LG SIGNATURE OLED T, LG is pioneering a future where technology and design coexist beautifully.
      With its compact design and powerful performance, the CineBeam Q delivers stunning 4K resolution and vibrant colors, transforming any space into a captivating theater. This state-of-the-art projector features advanced laser technology, ensuring exceptional brightness and clarity, even in well-lit environments. The LG CineBeam Q also offers versatile connectivity options, allowing seamless streaming from various devices, making it perfect for movie nights or gaming sessions. With its user-friendly interface and compact form, the LG CineBeam Q is designed to enhance your entertainment experience, setting a new standard for home projection.
      Furthermore, Signature Kitchen Suite’s 30-inch Combi Wall Oven, a product in the latest Transitional Series delivering a chic, minimalist appearance, has also been recognized as one of the Best Inventions of 2024 in the Household category.
      To learn more about the LG SIGNATURE OLED T and CineBeam Q, visit .
    • By Ramesh Chand Vishwakarma
      Regards,
      MD/CEO
      Noida, UP
      +91 9910246766
    • By starwoodtech
      I followed the instructions to set the default input on my TV, but every time I cold start it, it simply goes to the screen where there is a list of apps. I try to repeatedly go to the HOME app to try to set it again, even though it already shows HDMI 4 as the start up input, but it simpy goes to the default screen where my apps are listed.
      Does anyone know what it would take to set this?
