By u84six
By bos2prov
By Danster75
Hi all,
I'm Danny and have a problem with my LG OLED65C8;
since a few months when playing movies, either from my Syno NAS or just plain USB, subtitles are being displayed double (over or above eachother) or are displayed for sometimes minutes after the sentence's been spoken. The videofiles haven't got any hardcoded subs but either subs included in the mkv container or as separate srt of ssa file. Disabling subs removes the display of subs, enabling subs results in double or persistent subs.
Subtitles have been disabled in the accessability menu, factory reset did not help.
I searched but as far as I can see this problem has not been discussed yet, also googled and never came across this problem. Perhaps someone here can help?
Kind regards, Danny
SOLUTION, for me at least:
I used ColorControl to reboot the TV. It's weird that a factory reset did not work but a simple reboot did.
By Birkso
Have an LG55Nano which works well apart from when on specific BBC shows whereby whenever there is a switch if camera, say from contestants to host and vice versa, there is an extremely annoying flickering motion that takes place. May sound petty but any visitors comment on how distracting it can be.
Happens constantly on Richard Osmans House of Games, Impossible, Pointless and similar BBC programmes. Reported it but was told I had to get video clips for them to assist despite it being less than a year old. Life's too short. Any advice very welcome.
By John Bizeray
I recently updated the firmware on my LG43UH610V. Now I constantly get "Wired Lan cable disconnected" / "Wired network is connected" messages even while watching a video file from my NAS. The TV is connected and using the network while getting these messages. It has always been on a fixed IP address on the LAN.
Xbox Cloud live online, Browser looks and works superb but i just cant find the right controller
By andrew scott,
- 0 replies
- 1,725 views
Popup messages: Wired Lan cable disconnected / Wired network is connected 1 2 3 4 7
By John Bizeray,
- 204 replies
- 230,295 views
- 4 answers
- 26,609 views
- 3,335 views
Julio Henrique Morimoto
I've had an LG 47LB6500 for about five months now. I love the TV and it's great. Except one thing that I find irritating is a constant AV input popup that keeps reappearing over, and over, and over.
While watching any content from any input, the popup appears.
The only device plugged to the TV is an HDMI Sky HDTV Set Top Box, and there is nothing plugged into any AV input. WebOS seems to enter some variable loop, displaying several of these popups in sequence. Often, the number of popups is such, that the TV will freeze trying to show all of them. I can only assume a lot of its CPU is being used to render them. The TV will become unresponsive until all popups disappear. The annoyance may last a couple of minutes, but it happens everytime the TV is turned back on.
From the input configuration screen, I can see the AV input is active. .
Once it's removed, the popups are gone. But once the TV is turned off and back on, WebOS will scan for devices and these empty AV inputs are back on the list... and the parade of popups will follow.
As a user, I have to consder this a bug. And it's a very irritating one. These popups cover subtitles and seem to show up minutes after the TV is turned on. Please provide a fix with a firmware update or, at least, provide a workaround to make it stop.
Kind regards!
Julio
26 answers to this question
