    • By Trev
      1. For well over a year the Antenna Channel Guide has been incomplete. Is there a way to manually update the guide?
      The Prime app has suffered from two problems:
      2. No subtitle option on movies, fixed by app uninstall/reinstall. Is there an easier fix?
      3. 4K movies downgrade to SDR or SD momentarily, app uninstall/reinstall did NOT fix this?
      TV software is upto date. Internet speed is good. Cache has been cleared by power disconnect/reconnect.
      I have not tried Reset To Original settings, will that wipe out antenna channel & HDMI input name customizations?
      Thanks.
    • By The Old Man
      Hey LG
      Yes I am NOT happy
    • By SHawk
    • By Sqwazy
    • By majorusa
      - 3.23.24 - Romania- 47LB730v
