LG 47LB6520-TB (Symlink) not working after update :(
By Rex G
By Tobin
Tobin
By SHawk
By DavidSr
By Roy Brown
Hassan Al-Khadrawy
Friends,
I faced this issue (Symlink not working with my PlayStation 3 )after update to final version 04.62.50
what can i do now ???
Thanks and regards
