Just bought an LG TV with WebOS and am using the built in satellite tuner via an old Sky dish. Some of the channels get populated in the EPG, but most don't. Any idea if there's any way to fix this or any way to manually import EPG data?
4 answers to this question
Nope. I bought a better tv aerial instead, the lack of freesat epg means you can't set up recordings and there are too many channels missing from satellite anyway
    • By Peter_T
