How to reset cable's card parental control PIN?
By Regis Wheeler
By JasonB
By matesz
By matesz
PS2. I've heard that Denon AVR-X3600H works but this is massive overkill for what i need (i don't indend to go beyond stereo, not even 2+1).
wally45
Hi there,
I've got cable-TV decoded throw an inserted smartcard (CI+ Module). The card comes with a parental control pin activated, and I'm forced to insert it way too many times. In the card's documentation says that the TVs should have a many to remove the lock, however I can not find it in mine. This is NOT the webOS's built-in security PIN, that one is completely deactivated, and the input even looks different. Does anyone have any clue?
Model : 55LB630V
webOS: 04.32.20
Thanks.
