Looks like HP may have found another warehouse with some Touchpads. Word is that we can expect a second Fire Sale at those unbelievable prices we saw this past weekend. Keep checking HP, I'm sure once it goes live, they'll be gone quick. :wacko:
Check out the article on PreCentral:
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
    • By Rosie
      Fire TV upgraded and since then I'm unable to use my remote. I have to use the button below TV and have no freeview. Unable to get to settings to tune TV. Grateful for any advice
    • By ajmboy
    • By Alex
