By
wallyricks
My PC setup is: Windows 10 Pro (with all latest updates) and a TP-Link Archer BE19000 (BE805) router. NOTHING has been changed on my router, TV (no updated or changed firmware) or any equipment moved around in the last 4 months.
javilink
hello.
i am a new user in this forum. If you are so very kink, i want to ask you .. How to reduce the little jerks when i play media (films, tv series... etc) .avi, .mkv......that are inside an external hard drive that i´ve connected on usb port.
i have a LG 55lb730-ZD with 04.41.32 firmware.
I'm desperate... I have also disabled the TruMotion option...that perhaps it could remedy this but not
someone could help me.
regards
