Is the us version ub8500 the same as a ub850t
I am running 04.55.04 with a 49ub8500 but noticed the African and several other countries have a 49ub850t but it has a newer version of webOS 4.60.50.! My question is the tv seems the same as my ub8500 so I wonder if 4.63.50 will work on it? Thanks for any advice,help,or info! Also what are the chances 49 ub8500 will get webOS 2.0?
    • By NaveenKumar
    • By majorusa
      - 3.23.24 - Romania- 47LB730v
    • By Steve D B
    • By JohnoFon
    • By Ali Zia
