How Do I Upgrade LG TV 55LA9650 to WebOS
Hello Friends,
I had bought LG 55'' 3D TV exactly a year back which had older version of OS (not WebOS). Though I go to settings and check for the latest updates, it says you have the latest version.
My problem is to upgrade my TV with latest WebOS, can any suggest / recommend me on the steps, so that I can install them.
Appreciate your help in this regard.
9 answers to this question
Hello Friends,
Your only option is to upgrade your TV by replacing it with a more recent model.
Jimbo you'r wrong! You can order an upgrade kit from LG, i did it last weak, now a i can see netflix in 4K.
Any joy with the link or part number? Loads of people looking forward to ordering this upgrade!
C'mon Osse5 - surely you can throw SOME light on your claims? You wouldn't want anyone to think you were simply trolling?
Jimbo is 100% wrong if you call LG there is a upgrade kit for the 9650 and the 9700 series to upgrade the units to webOS and give you upgraded HDMI 2.0 support HVEC also just call them up they will be confused as hell cause no one there knows what the hell they are talking about then finally with they transfer you to tech support the techs will know its about $400
    • By Prakash Sahoo
      Hi Team,
      Prakash Sahoo
    • By Jaswinder Sandhu
