My lg tv lb6520 not openning youtube
By Lee Magee
By Will M
By David Joseph
By Владимир Морозов
By JonoW
Muhammad Noman
How l will open the youtube.when I open it give dns error 3.while my samsung tv is opening it .how I will fix this problem.
