  • 1
how you watching movies from pc? some videos, i can play from pc, others no. why? bigger files like mkv format with more 5gb not are recognized, per times, i bob system by dragging the largest files for windows streaming window, but does not always work, I'm finding this solution rather archaic. help me. i have two LF6350 models, 43" and 49".
I use Plex and the Playz tv app. I do have to strip any subtitles out of mkv's using mkvmerge though, as the tv will display them no matter what settings are chosen.
    • By wallyricks
    • By Bella Lee
    • By Gregor Huc
    • By Abhishek_02x
      I am using the lg tv from 2 years and I found an amazing experience till now.
      But I like request about Play box TV app. Please add this app in store section so that I could download it on my tv.
      It would be helpful if you respond to my email. This app is very demanding now a days as it comes with the excitel broadband service.
    • By keshav iyer
