Youtube app disappeared?
By JonoW
By Stephen Pritchard
For some reason the scroll right and left arrows have disappeared from the youtube app when using my mouse.
I've tried installing the app again but no luck.
Any ideas?
By Владимир Морозов
By Low Grade
hi,
By netsplit
Dave Adams
I had the youtube app, did a factory reset yesterday and all apps I had previously are there EXCEPT the youtube app. I've tried looking in the Tvs LG app store, but it's not listed - HELP!!! Im in the UK and the model is LG 55UF950V (manufactured March 2015).
Dave
