Windows 10 miracast widi
Hi everyone
I have a question about miracast function after update to windows 10
Do You have a problem with connect pc to the TV ? I have, now ;/
When I want to connect TV by add device on the tv screen i see this information "can't connect with device"
What's happened ?
Do You think this is Windows fault ? Or TV LG software ?
Please reply
(if my language has got a lot of mistake, im sorry but I do best i can )
6 answers to this question
I also encounter problem with connecting to my 42LB631 after upgrading to Windows 10 from 8.1.
I updated all Network, Adaptor display driver to the latest one. When I connect my laptop from Action Center, it announces Connected but the TV screen is black and after few seconds it shows an error message of "MIRRORING ERROR, we can't mirror your device screen connected via Miracast. Check you device"
In previous Window 8.1, it worked very well.
I'm waiting for a solution maybe from Intel, Microsoft or LG.
    • By wallyricks
    • By Marko00
      only with cancel button.
      How to fix it?
    • By bogeyman62
      Has anyone been able to run Screen Share from a Windows 10 PC? Mine will not connect to the LG TV.
    • By GMosley
      I have three LG Smart TVs in my home. I have a Windows 11 PC with videos on the hard drive. It seems like I should be able to connect to the PC videos from any one of the TVs. When I "show all inputs" on the TV, the PC shows up. When I select it, I get the message "Device not connected". All devices are connected to the home wifi network. I also have LG's SmartShare running on the PC and the video folder has been selected for sharing.
      Any suggestions?
      Thanks.
    • By JeanF
      Is-it possible to have another navigator like Firefox in addition to WebOS ? How ?
