Need help with LG 60UB8200 | Turning off screen saver!
We want to use them to show a picture constantly, but screen saver keeps on turning on.
Firmware is upgraded to the latest one, and turned eco mode off. No luck. ( SOFTWARE FILE(VERSION 04.11.08)
I thought of copying the same files to multiple copies so the tv can go through it as slide shows but it will still sop in the end and not repeat.
If I copy the files to the TV hard drive, will it help?
I tried researching into this issue, but no luck.
Called and contacted LG, tech support told me that I purchased the wrong TV? I am not even sure what that means, I guess I should have looked into another brand.
10 of these guys are installed now so I want to save the hassle and not return them.
Thanks for any suggestion and input!
    • By DWINKS49
    • By Batman
    • By MNHL
    • By Prashant Chavan
      Please add Jio TV app in upcoming software update.
