Miracast not workn properly
By CJ Catalano
By Paul Griffith
When I try to go to a TV programme via the remote control voice option, the TV tries to look up the channel on the app I'm on, instead of going straight to the TV channel on the antenna. This used to work without any problems up until a couple of days ago. Any help appreciated.
By Alfvenwave
Hi, I'm curious if anyone else is seeing this annoying new behaviour.
I have my SKY Q box on HDMI1 and have become accustomed to switching back from Netflix (or any other app for that matter) by having HDMI1 assigned to button "1" using the Quick Access feature. In the last week though, this feature has stopped working properly. If I am in Netflix and I press the "1" button, nothing happens (as expected). If instead I hold down the "1" button to switch to SKY I get a pop up that says this: "Do you want to add Netflix to [Quick Access 1]?". If I then hold down the "0" button, the 3x3 grid "EDIT QUICK ACCESS" pop-up appears and I can clearly see my SKY Q/HDMI 1 in the top left grid position (button "1")!!!
If I then switch via the Home button to HDMI1 and remove HDMI1 from Quick Access (via the EDIT QUICK ACCESS pop up), I can then re-add it by holding down 1 or from within the pop-up. Now, if I go into Netflix and then hold down 1, my TV does (correctly) switch to HDMI1. Hurrah! If however I turn my TV off and back on, then go to Netflix, then hold down "1", I am back to square one with the question "Do you want to add Netwflix to [Quick Access 1]?"......Grrrr!!!
I have tried switching the TV off at the wall, leaving for 10 seconds and repowering, which doesn't fix the problem (I don't believe WebOS reboots when you do this). LG appear to have made it a practical impossibility to reboot WebOS via anything other than a factory reset which I don't really want to do as it'll take me too long to get all my settings back to where I have them now. Some blogs suggest that the "User Licence agreement" setting can be changed which forces a reset from within the General tab but I don't see this on my TV (guessing that WebOS interface has changed).
Anyone have any ideas?
Rob.
By JuliusCaesar
Hey guys,
this might seam like a primitive question for you but I'm having trouble connecting my TV via Miracast with my MS Surface Tablet.
Wenn I open Projector Settings (Windows + P) and select "connect with wireless display" my LG Webos TV is found by my Surface.
Now when I hit "Connect" MS Surface trys to establish a connection with the LG Smart TV. However the LG TV does not show any message like "Accept Wireless connection". I'm guessing this is the reason why my Miracast does not work.
Could you help me out here? Where did LG hide the confirmation dialogue?
thx for your help
greets :)
By Rodrigo Gómez Maitret
Hello!
My parents' LG webOS TV had this issue where their Magic Remote has gone insane and every button thinks it is the mute button.
I have tried changing the batteries to brand new ones, letting it fully "de-charge" for 10 minutes, de-pairing it, etc. accordingly to the troubleshooting guide. Not even the power button blinks as it should. Oddly enough, the motion cursor works fine.
I have attached a video to show how it looks.
Any suggestions to fix this?
VID-20200327-WA0015.mp4
