43LF6300 Application has not been instaled. Try again
when i try to install/update Application in 43LF6300, giving a pop-up "Application has not been instaled. Try again"
i called customer care 5 time and they said "arranged a call back", but i din't recieve till now, i am frustated with LG Customer Care guy's.
can any please help me guys.
    • By Calvinder
      One suggestion was to go to Settings>all settings>general>AI Service>Voice recognition service and change to LG ThinQ.
      But the  Voice recognition service tab is gone. There is only voice recognition settings tab
      I would rather not have to reset to factory settings unless there is a way to save / export my current seating's
      Any suggestions
    • By Junaid Ahmed
    • By Ganesh R
      Hi LG Team,
      Regards,
      Ganesh R
    • By jikhead
      I'm not getting any audio from the apps via the HDMI via ARC connection to my receiver.  This occurred two weeks ago and was unable to resolve it, but ironically there was new firmware released that same day for my B6 (3/31/17) and this fixed the issue.  However, now I again can't get it working after a TV reset and tinkering with the audio settings again.  I tried to load the firmware again, but it appears this is not possible to forceable load the same firmware.
