LG SMART TV WEB OS PROCESSOR & RAM INFORMATION
By Will M
By Lesbo
By Rex G
By Mogens
Kind regards
Mogens
rohit.ksingh9
prGuys ! Is there any ways so that we can check the processor quality with physical RAM used in LG SMart TV
like dual or quad core with 2-4 GB ram
9 answers to this question
