LG 55LA 690V-ZB problem
By PVD
By hollean
By AJO
By BozaB
I need help, I bought LG Oled 65 C41 LA tv two days ago, tv is working mostly fine, except when I watch LG installed streaming platforms ( Netflix and MAX tested ) tv freezes and after about 10 seconds it restarts. It does not have any pattern as far as I know, sometimes I can watch 20 mins, last two times after six minutes it crashed and restarted automatically. Can someone please help me, how can I resolve this issue? Did someone had sam problems already? Is my tv broken or I can do something to fix it?
By DeJaVu
bigterd
Hi, bought 2 of these almost exactly 2 years back.
1 has failed, no picture just sound, lines up and across the screen, some shadowing to centre of black screen..
Any pointers/
Looking for local rep/tech etc, but does this smack o0f a common issue/
Cheers regardless
