TV controlling Sky+HD box?
Hello
Just bought a
LG 40LF630V
It seems to suggest that there is integration with a Sky+HD box, but the set up on the TV never manages to succesfully make the Sky+HD box do anything. The Sky box is connected to HDMI1
Is there anything special I need to do? To either the TV or the Sky box? HDMI control is turned on, on the Sky+HD box
Happy with this TV so far mind you. It's even got decent built-in sound.
    • By SHUZ
      I have several LG Webos TVs.  One started doing this a long while back.  Just this week another started doing the same. They have streaming devices on hdmi ports.  To change channels and general navigation i could always use the up down left right buttons.  But now I get the he hdmi port with the multi audio icon below.  Something has to have been toggled to make this happen.  Factory reset doesn’t fix it.  How do I access my streaming device from my lg remote again?
    • By bcarmien
      Is it possible to configure the Magic Remote to control a XBox One S? If so, how?
      I have tried using the device connector feature in WebOS of my 55EF9500. Is this possible?
      Thanks in advance.
    • By slewis7
      The Magic Remote has universal remote control support for a number of different sound bar brands, but not for Definitive Technology and their W Studio sound bar model.  I would like to see this support added.  It would also be nice if the interface allowed manually setting the remote control codes for various functions, in the case where corresponding devices are not listed.
