WEB OS - Not in use from Start
This is Kalai from Chennai, recently bought a LG smart LED TV. 47LB750T.
From the start am unable to use WEB OS apps. It says Network is Unstable. But Browser works fine and my Wi-Fi connection is stable.
My current Software version is 04.65.05
And WEB OS version is 1.3.4-3953 (afro-arches)
Please help me to fix this.
    • By starwoodtech
    • By denisuu
      Hi all,
      I'm wondering how you can get into the service menu (In Start) on an old LG Smart TV (42LB630V) running WebOS 1.4.  I have a Samsung Galaxy S6 (SM-G920F) with a IR blaster, I have tried sending '0x04FB 0xFB04' to I which should be IR code to enter the menu, but that doesn't work.
    • By Renver
      When i power on my OLED55C8PLA TV it always starts at the source 'SET UP BOX' even there is no set up box connected. We only use HDMI2. That is also always the used source when we power down the TV. Its quite anoying the TV doesnt starts the input last used.
      I hope someone can help me with this issue!
      Thanks!
    • By Extra Celestial
      Would love to auto start the Alexa app so my smart home can connect to it automatically when I turn it on from a plug since you can't turn on the tv with the hubs.
      One small workaround instead of trying to figure out how to turn on the tv from a hub since it disconnects from the wifi when it powers off.
    • By margorjon
      Hello, I would like to get our new TV to show the home screen at startup instead of a Rakuten channel were never interested in.
      I have set the settings to show the home screen at startup yet it's still not working, at startup were still only getting Rakuten...
