Bluetooth Headphones
By JamesH
By Fredrik Andersson
By ato53
I have a new C4 TV.
Thanks for the follow-up
By Kane Murphy
By John Nguyen
harpingon
Hello
Trying to connect bluetooth headphones to LG webOS TV
40LF630VThe specs on LG website say TV supports apt-X , which is enhanced bluetooth audio, and so do my headphones.
So how exactly do I connect bluetooth headphones to the TV? I have a bluetooth headphone dongle that I was using with my old TV, but seeing as this new LG supports apt-X I was hoping to ditch the dongle (which needs to be charged up etc) and connect to the TV directly.
As often, the manual is scant on this (what manual).
Cheers
