HELP: LG LB65XX TV, reset but cant click 'OK' with magic remote so initial setup halted
By John Nguyen
By Rizwan Sumra
By Peter Payne
- 242 views
- 3 replies
- 1,482 views
- 694 views
- 1 answer
- 757 views
ripansays
Hi to all....
MY TV is LB6520 42 inch with firmware v 4.65.XX
From yesterday, suddenly the magic remote stopped working except the cursor was moving on screen & using the wheel on remote channel change was working. All the buttons & clicks stopped working.
Even my LG blu ray player remote which I use for operating TV on/off, volume, channel change etc. Stopped working.
But the android LG TV Plus app was working smoothly. So using the app, I reset the TV from 'Settings' menu. Now at primary initialization phase where 'Language' & 'Country' selection is done, I cant click on 'OK' button [as no button/clicks are working on both the remotes]. Screenshot attached. So I struck on this screen & can't proceed.
Is there any other way to perform the clicks for initial setup like using laptop, mouse etc.?
Please Please Hep me.
Note: TV bought from UAE. Now I'm in Bangladesh. Country was set to S Africa. No problem I faced in my 1 year operation of the TV.
- Ripan
7 answers to this question
