Hello everyone. I just buyed my new LG Smart Tv and when i try to watch a movie or a tv show throw Plex TV, the LG doesn't recognize my subtitle. On my PC, in Plex App, if i try to watch the same movie the subtitle works fine. But when I try to watch it on the TV it doesn't appear on the subtitle menu, even the subtitle menu is gray.
Can someone help me with that please?
    • By wallyricks
    • By murastefano
      How to show video cover art on  SmartShare on WebOS ?
      I have many movies, mp4 or mkv file with cover art muxed,  but SmartShare
    • By DeJaVu
    • By Tsmt
      I have a problem with the subtitles when I try to share a video wirelessly directly from my PC to my LG 55SM9010PLA TV. I am not talking about sharing the whole screen (it lags a bit), just the video itself.
      Sharing the video itself works well, but randomly the TV randomly does not recognise the subtitle, the sub option is not active in the TV menu, and there are no subtitles. It is in the same folder on my PC as the movie (.mkv), with the same name. In case of some movies it works, in case of others not, and I do not see the reasons why.
      First I tought it is becouse the format of the subtitle needs to be ".sub", becouse it worked with one movie. So I have learnt how to convert properly ".srt" to ".sub" - but still no success.
      Then I realised, in the case of another movie ".srt" worked on the TV, so I got really confused.
      I see no logic behind it.  Could you help me, what is the key here, what am I missing?
      Thank you!
    • By Wondering
