Did you try this app?
Yes, you can open file with list of channels, and you sort them, but  when I put file back to TV, channels become totaly in random order on TV.,.
I try this on 42LB671v
is what I was complaining about in this post ,(
major defects,)
webos not be excluded automatically update channels if you walk into that section , terrestrial , cable or satellite and then a channel is not admissible , webos eliminates the channel and automatically does a reorganization wants com he result you are messed up channels , and sat in the section if you have more satellites you melee channels in succession also of different satellites .
Again if you have a motorized dish becomes a mess .
there should be the ' option in the three sections separately , search / automatic update stations yes / no, instead does everything automatically , a beautiful chaos .
sections : = terrestrial , cable , satellite
we shall now see in ' update web os 1.x as it is not precisely 2.0 due to differences ram second level which in products in 2014 was 256 while in the production of 2015 is 512mb , and the processor was brought to + , thus faster if they will have at least correct this obrobrio management channels .
sorry for my English , I use to write here traslator
Blackeyed, what happens when you put file back to TV without editing in this application? Is this feature works properly on your TV?
Honestly, I did not try this. As soon as I aranged my channel back to normal (spend some almost half an hour)  I dont want I try what you suggested.
