Question how to start the broser automatically
Hello dudinir,
Unfortunately, it is not possible.
Thanks simon for your quick answer.
Very disappointing that so many basic functions are missing
Sent from my LG-H815 using Tapatalk
    • By JamesH
    • By starwoodtech
    • By starwoodtech
    • By denisuu
      Hi all,
      I'm wondering how you can get into the service menu (In Start) on an old LG Smart TV (42LB630V) running WebOS 1.4.  I have a Samsung Galaxy S6 (SM-G920F) with a IR blaster, I have tried sending '0x04FB 0xFB04' to I which should be IR code to enter the menu, but that doesn't work.
    • By Fricassee
