Hello everyone
I need a hint on how to solve the following problem:
I've got 42lb653v webos tv and lg nb3740 soundbar (packin' netcast platform) which is connected to my tv via fine optical cable
Everything is working fine until i launch Youtube app - when I click to play any video, it's 70% possibility that there won't be any sound..
after 3-4 cycles of quitting and entering the same video, the sound finally appears. sometimes everything's okay, e.g. i hear sound from the first attempt.
this problem isnt very critical, but quite irritating. I'd like to read any tips from you. thx in advance.
    • By crct
    • By hollean
    • By Lee Magee
    • By DeeDeee
    • By Will M
