60LB7500 out of memory after update
Hi all........
Ok so after the latest firmware update i now get a error message "This app will now restart to free up more memory"
only seems to happen 30min - 45min after its first turned on and then every few minutes after that until its turned off and on again!!!!
Any ideas???
60LB7500
05.00.04
1.4.0-2504 (afro-ashley)
Hi all........
Any ideas???
60LB7500
05.00.04
My LG tv keeps on repeating that the app is restarting to free up more space on whatever app I'm on and it happens every 10 seconds so I can't even look at the settings. It even happens when I'm on my ps4 which is on HDMI 1. Any Ideas?
    • By mean2
    • By OliverRC
    • By Ajothen
    • By atcronin
