FIXED !
Turned of windows firewall and it works.
And yes i clicked on allow when it popped up
But still i had to disable it.
(Windows 10)
Okay mtuna10, check this shit...
1. Download
 and put into C:\LgDTVUpDater\htdocs
a. Fix filename ...V3_SECURED%5B0%5D.epk > ...V3_SECURED.epk
2. Edit HE_DTV_W15U_AFADABAA file in C:\LgDTVUpDater\htdocs
<RESPONSE><RESULT_CD>900</RESULT_CD>
<MSG>Success</MSG>
<REQ_ID>00000000002517882554</REQ_ID>
<IMAGE_URL>
<IMAGE_SIZE>699098426</IMAGE_SIZE>
<IMAGE_NAME>starfish-dvb-secured-lm15u-badlands-453201-03.03.06-prodkey_nsu_V3_SECURED.epk</IMAGE_NAME>
<UPDATE_MAJOR_VER>03</UPDATE_MAJOR_VER>
<UPDATE_MINOR_VER>03.06</UPDATE_MINOR_VER>
<FORCE_FLAG>Y</FORCE_FLAG>
<KE></KE><GMT>10 Jun 2015 19:19:20 GMT</GMT>
<ECO_INFO>01</ECO_INFO>
<CDN_URL>
<CONTENTS></CONTENTS></RESPONSE>
a. Copy all and overwrite with HE_DTV_W15U_AFADABAA file content
b. Change 192.168.0.11 with your local IP address
3. Run downgrade process follow my tutorial
4. If all goes well, remember to restore DNS settings on TV and then you can check for OTA updates if you want.
If goes wrong...
Well, then you have to do something with your connection. Maybe another computer, another place, another connection... It has to work.
So, good luck and let me know.  ;)
Hi Simon,
Thanks a lot for your help but unfortunately this did not work for me either :( I have disabled both my Kaspersky and Windows firewalls, then I have downloaded the software file to the "htdocs" folder and modified the "HE_DTV_W15U_AFADABAA" file with the content above and with my computer's IP address but still no luck (the online method also failed), my in_dump.txt file is not updated and my TV cannot find any updates :( I guess I will have to try this on a different computer, that is my option left.
By the way, here are the "startDNS.bat" log entries I receive using the local method (while Apache window does not create any):
Acrylic DNS Proxy Console Version                          Press ENTER To Quit
2015-10-25 11:12:10.153 TBootstrapper.StartSystem: Loading configuration file...
2015-10-25 11:12:10.153 TBootstrapper.StartSystem: Loading address cache items...
2015-10-25 11:12:10.153 TBootstrapper.StartSystem: Loading hosts cache items...
2015-10-25 11:12:10.153 TBootstrapper.StartSystem: Starting resolver...
2015-10-25 11:12:42.406 TResolver.Execute: Request  ID 45091 received from client 192.168.2.146:50667 regarding "lgtvonline.lge.com" of type A.
2015-10-25 11:12:42.406 TResolver.Execute: Response ID 45091 sent to client 192.168.2.146:50667 directly from address cache.
2015-10-25 11:12:48.165 TResolver.Execute: Request  ID 46002 received from client 192.168.2.146:54631 regarding "snu.lge.com" of type A.
2015-10-25 11:12:48.165 TResolver.Execute: Response ID 46002 sent to client 192.168.2.146:54631 directly from hosts cache.
2015-10-25 11:12:48.165 TResolver.Execute: Request  ID 65312 received from client 192.168.2.146:54631 regarding "snu.lge.com" of type AAAA.
2015-10-25 11:12:48.165 TResolver.Execute: Response ID 65312 sent to client 192.168.2.146:54631 directly from hosts cache.
2015-10-25 11:12:53.176 TResolver.Execute: Request  ID 09350 received from client 192.168.2.146:54631 regarding "snu.lge.com" of type AAAA.
2015-10-25 11:12:53.176 TResolver.Execute: Response ID 09350 sent to client 192.168.2.146:54631 directly from hosts cache.
2015-10-25 11:12:53.280 TResolver.Execute: Request  ID 62264 received from client 192.168.2.146:54631 regarding "TR.lgtvsdp.com" of type A.
2015-10-25 11:12:53.280 TResolver.Execute: Response ID 62264 sent to client 192.168.2.146:54631 directly from address cache.
2015-10-25 11:12:53.381 TResolver.Execute: Request  ID 64750 received from client 192.168.2.146:54631 regarding "TR.lgtvsdp.com" of type AAAA.
2015-10-25 11:12:53.397 TResolver.Execute: Response ID 64750 sent to client 192.168.2.146:54631 directly from address cache.
2015-10-25 11:12:54.898 TResolver.Execute: Request  ID 55989 received from client 192.168.2.146:54631 regarding "TR.info.lgsmartad.com" of type A.
2015-10-25 11:12:54.898 TResolver.Execute: Response ID 55989 sent to client 192.168.2.146:54631 directly from address cache.
2015-10-25 11:12:54.898 TResolver.Execute: Request  ID 51685 received from client 192.168.2.146:54631 regarding "TR.info.lgsmartad.com" of type AAAA.
2015-10-25 11:12:54.913 TResolver.Execute: Response ID 51685 sent to client 192.168.2.146:54631 directly from address cache.
2015-10-25 11:12:57.126 TResolver.Execute: Request  ID 34333 received from client 192.168.2.146:35124 regarding "lgtvonline.lge.com" of type A.
2015-10-25 11:12:57.126 TResolver.Execute: Response ID 34333 sent to client 192.168.2.146:35124 directly from address cache.
2015-10-25 11:12:59.184 TResolver.Execute: Request  ID 60073 received from client 192.168.2.146:54631 regarding "snu.lge.com" of type AAAA.
2015-10-25 11:12:59.184 TResolver.Execute: Response ID 60073 sent to client 192.168.2.146:54631 directly from hosts cache.
2015-10-25 11:13:08.208 TResolver.Execute: Request  ID 40105 received from client 192.168.2.146:54631 regarding "TR.lgrecommends.lgappstv.com" of type A.
2015-10-25 11:13:08.208 TResolver.Execute: Response ID 40105 sent to client 192.168.2.146:54631 directly from address cache.
2015-10-25 11:13:08.224 TResolver.Execute: Request  ID 10084 received from client 192.168.2.146:54631 regarding "TR.lgrecommends.lgappstv.com" of type AAAA.
2015-10-25 11:13:08.224 TResolver.Execute: Response ID 10084 sent to client 192.168.2.146:54631 directly from address cache.
2015-10-25 11:13:12.187 TResolver.Execute: Request  ID 07997 received from client 192.168.2.146:54631 regarding "snu.lge.com" of type AAAA.
2015-10-25 11:13:12.187 TResolver.Execute: Response ID 07997 sent to client 192.168.2.146:54631 directly from hosts cache.
2015-10-25 11:13:13.118 TResolver.Execute: Request  ID 37792 received from client 192.168.2.146:54631 regarding "snu.lge.com" of type AAAA.
2015-10-25 11:13:13.118 TResolver.Execute: Response ID 37792 sent to client 192.168.2.146:54631 directly from hosts cache.
2015-10-25 11:13:18.120 TResolver.Execute: Request  ID 09013 received from client 192.168.2.146:54631 regarding "snu.lge.com" of type AAAA.
2015-10-25 11:13:18.135 TResolver.Execute: Response ID 09013 sent to client 192.168.2.146:54631 directly from hosts cache.
2015-10-25 11:13:18.916 TResolver.Execute: Request  ID 55308 received from client 192.168.2.146:54631 regarding "www.google.com" of type A.
2015-10-25 11:13:18.931 TResolver.Execute: Response ID 55308 sent to client 192.168.2.146:54631 directly from address cache.
2015-10-25 11:13:19.198 TResolver.Execute: Request  ID 04110 received from client 192.168.2.146:54631 regarding "www.youtube.com" of type A.
2015-10-25 11:13:19.198 TResolver.Execute: Response ID 04110 sent to client 192.168.2.146:54631 directly from address cache.
2015-10-25 11:13:20.565 TResolver.Execute: Request  ID 63899 received from client 192.168.2.146:54631 regarding "googleads.g.doubleclick.net" of type A.
2015-10-25 11:13:20.565 TResolver.Execute: Response ID 63899 sent to client 192.168.2.146:54631 directly from address cache.
2015-10-25 11:13:20.715 TResolver.Execute: Request  ID 65045 received from client 192.168.2.146:54631 regarding "www.youtube-nocookie.com" of type A.
2015-10-25 11:13:20.715 TResolver.Execute: Response ID 65045 sent to client 192.168.2.146:54631 directly from address cache.
2015-10-25 11:13:22.053 TResolver.Execute: Request  ID 08404 received from client 192.168.2.146:54631 regarding "www.googleapis.com" of type A.
2015-10-25 11:13:22.053 TResolver.Execute: Response ID 08404 sent to client 192.168.2.146:54631 directly from address cache.
2015-10-25 11:13:22.731 TResolver.Execute: Request  ID 35416 received from client 192.168.2.146:54631 regarding "localhost" of type A.
2015-10-25 11:13:22.748 TResolver.Execute: Response ID 35416 sent to client 192.168.2.146:54631 directly from hosts cache.
2015-10-25 11:13:22.754 TResolver.Execute: Request  ID 24381 received from client 192.168.2.146:54631 regarding "yt3.ggpht.com" of type A.
2015-10-25 11:13:22.754 TResolver.Execute: Response ID 24381 sent to client 192.168.2.146:54631 directly from address cache.
2015-10-25 11:13:23.283 TResolver.Execute: Request  ID 31610 received from client 192.168.2.146:54631 regarding "i.ytimg.com" of type A.
2015-10-25 11:13:23.283 TResolver.Execute: Response ID 31610 sent to client 192.168.2.146:54631 directly from address cache.
2015-10-25 11:13:23.656 TResolver.Execute: Request  ID 55972 received from client 192.168.2.146:54631 regarding "s.ytimg.com" of type A.
2015-10-25 11:13:23.656 TResolver.Execute: Response ID 55972 sent to client 192.168.2.146:54631 directly from address cache.
2015-10-25 11:13:24.145 TResolver.Execute: Request  ID 08217 received from client 192.168.2.146:54631 regarding "snu.lge.com" of type AAAA.
2015-10-25 11:13:24.145 TResolver.Execute: Response ID 08217 sent to client 192.168.2.146:54631 directly from hosts cache.
2015-10-25 11:13:27.154 TResolver.Execute: Request  ID 03780 received from client 192.168.2.146:54631 regarding "mqbgctrt" of type A.
2015-10-25 11:13:27.169 TResolver.Execute: Request  ID 03780 forwarded to server 8.8.8.8:53.
2015-10-25 11:13:27.169 TResolver.Execute: Request  ID 03780 forwarded to server 208.67.220.220:53.
2015-10-25 11:13:27.169 TResolver.Execute: Request  ID 44820 received from client 192.168.2.146:54631 regarding "ohuguskjhcmzt" of type A.
2015-10-25 11:13:27.169 TResolver.Execute: Request  ID 44820 forwarded to server 8.8.8.8:53.
2015-10-25 11:13:27.185 TResolver.Execute: Request  ID 44820 forwarded to server 208.67.220.220:53.
2015-10-25 11:13:27.185 TResolver.Execute: Request  ID 03581 received from client 192.168.2.146:54631 regarding "urzpispj" of type A.
2015-10-25 11:13:27.185 TResolver.Execute: Request  ID 03581 forwarded to server 8.8.8.8:53.
2015-10-25 11:13:27.185 TResolver.Execute: Request  ID 03581 forwarded to server 208.67.220.220:53.
2015-10-25 11:13:27.239 TResolver.Execute: Response ID 03780 received from server 8.8.8.8:53.
2015-10-25 11:13:27.239 TResolver.Execute: Response ID 03780 sent to client 192.168.2.146:54631 and put into the address cache as negative.
2015-10-25 11:13:27.239 TResolver.Execute: Request  ID 23714 received from client 192.168.2.146:54631 regarding "mqbgctrt" of type A.
2015-10-25 11:13:27.254 TResolver.Execute: Response ID 23714 sent to client 192.168.2.146:54631 directly from address cache.
2015-10-25 11:13:27.254 TResolver.Execute: Response ID 44820 received from server 8.8.8.8:53.
2015-10-25 11:13:27.254 TResolver.Execute: Response ID 44820 sent to client 192.168.2.146:54631 and put into the address cache as negative.
2015-10-25 11:13:27.270 TResolver.Execute: Request  ID 17641 received from client 192.168.2.146:54631 regarding "ohuguskjhcmzt" of type A.
2015-10-25 11:13:27.270 TResolver.Execute: Response ID 17641 sent to client 192.168.2.146:54631 directly from address cache.
2015-10-25 11:13:27.270 TResolver.Execute: Response ID 03581 received from server 208.67.220.220:53.
2015-10-25 11:13:27.270 TResolver.Execute: Response ID 03581 sent to client 192.168.2.146:54631 and put into the address cache as negative.
2015-10-25 11:13:27.286 TResolver.Execute: Response ID 03581 received from server 8.8.8.8:53.
2015-10-25 11:13:27.286 TResolver.Execute: Response ID 03581 discarded because no session cache entry matched.
2015-10-25 11:13:27.286 TResolver.Execute: Request  ID 47592 received from client 192.168.2.146:54631 regarding "urzpispj" of type A.
2015-10-25 11:13:27.303 TResolver.Execute: Response ID 47592 sent to client 192.168.2.146:54631 directly from address cache.
2015-10-25 11:13:27.486 TResolver.Execute: Response ID 44820 received from server 208.67.220.220:53.
2015-10-25 11:13:27.486 TResolver.Execute: Response ID 44820 discarded because no session cache entry matched.
2015-10-25 11:13:27.486 TResolver.Execute: Response ID 03780 received from server 208.67.220.220:53.
2015-10-25 11:13:27.486 TResolver.Execute: Response ID 03780 discarded because no session cache entry matched.
2015-10-25 11:13:28.804 TResolver.Execute: Request  ID 22463 received from client 192.168.2.146:54631 regarding "ssl.gstatic.com" of type A.
2015-10-25 11:13:28.804 TResolver.Execute: Response ID 22463 sent to client 192.168.2.146:54631 directly from address cache.
Hey mtuna10. I'm sorry with still no success. The log looks like not being able to recognize your TV, so there is no answer in in_dump file. I think that this 04.10.10 firmware was inappropriate for your TV. I'm still looking for the right solution.
Sent from my iPhone using Tapatalk
Hi Simon, yes, the problem is almost certainly related to my TV model or its current software version 04.10.10 because I have tried all I could to eliminate any possible network issues.
I have picked up an old laptop (with Windows XP) from the office, disabled the Windows firewall, made sure that only this computer and my TV is connected to my router via ethernet (I have even disabled WiFi on my router and on my TV) but still the TV could not find any updates.
I guess I am stuck with 04.10.10 :(
Hi, i need a little help. I did the downgrade following the tutorial but now i cant see any channel with my TV, every channel is just noise sound and a black screen, i have tried to tune in the channels via manual and automatic methods but nothing works. The model of my TV is 49UB8500 and i am in firmware atsc 05.00.20 (not dvb) . This is the info of the in_dump file. I am from chile, thanks in advance for any help.
<REQUEST>
<PRODUCT_NM>webOS</PRODUCT_NM>
<MODEL_NM>HE_DTV_WT1H_AFAAATAA</MODEL_NM>
<SW_TYPE>FIRMWARE</SW_TYPE>
<MAJOR_VER>04</MAJOR_VER>
<MINOR_VER>62.43</MINOR_VER>
<COUNTRY>CL2</COUNTRY>
<DEVICE_ID>3c:cd:93:21:1b:51</DEVICE_ID>
<AUTH_FLAG>N</AUTH_FLAG>
<IGNORE_DISABLE>N</IGNORE_DISABLE>
<CONFIG_KEY>00</CONFIG_KEY>
<LANGUAGE_CODE>es-CL</LANGUAGE_CODE></REQUEST>
Hi Ignacio,
1. Download
 and unzip to C:\LgDTVUpDater\htdocs
2. Edit HE_DTV_WT1H_AFAAATAA file in C:\LgDTVUpDater\htdocs
<MSG>Success</MSG>
<REQ_ID>00000000001417347020</REQ_ID>
<IMAGE_URL>
<IMAGE_SIZE>592704168</IMAGE_SIZE>
<IMAGE_NAME>starfish-atsc-secured-goldfinger-5703.angeles.atsc-570303-03.23.06_usb_V3_SECURED.epk</IMAGE_NAME>
<IMAGE_CHECKSUM>0x83990faa</IMAGE_CHECKSUM>
<UPDATE_MINOR_VER>23.06</UPDATE_MINOR_VER>
<KE></KE>
<GMT>16 Aug 2014 16:11:22 GMT</GMT>
<CDN_URL>
a. Copy all and overwrite with HE_DTV_WT1H_AFAAABAA file content
4. After all remember to restore DNS settings on TV and then you can check for OTA updates
 Good luck and let me know.  ;)
mtuna10, let's try again...  :rolleyes:
1. Download
<MSG>Success</MSG>
<IMAGE_URL>
<CDN_URL>
3. Edit AcrylicHosts.txt file in C:\LgDTVUpDater\dns
# IF YOU MAKE ANY CHANGES TO THIS FILE YOU HAVE TO RESTART THE ACRYLIC DNS #
# PROXY SERVICE IN ORDER TO SEE THEIR EFFECTS. #
# This is the AcrylicHosts.txt file. #
# It contains predefined mappings between names and addresses exactly the #
# same way the native HOSTS file does. #
# The format is: IPADDRESS HOSTNAME1 [HOSTNAME2] [HOSTNAME3] ... #
# Where IPADDRESS is in quad-dotted notation and HOSTNAMES are strings. #
# The separator between IPADDRESS and HOSTNAMES can be any number of spaces #
# or tabs or both. If the HOSTNAMES contain the special characters '*' and #
# '?' a (slow) "dir" like pattern matching algorithm is used instead of a #
# (fast) binary search within the list of host names: #
# 127.0.0.1 ad.* ads.* #
# If a HOSTNAME starts with the '/' character instead it is treated like a #
# regular expression (also very slow compared to a binary search): #
# 127.0.0.1 /^ads?\..*$ #
# Note: More info about the regular expression engine and its syntax can be #
# found at: #
# It is also possible to specify exceptions when regular expressions or #
# pattern based matching is used. If for example we would like to filter #
# out all ads.* like domains except for the ads.test1 and the ads.test2 we #
# should write: #
# 127.0.0.1 ads.* -ads.test1 -ads.test2 #
# Note: A line starting with the '#' character (and everything after it if #
# it's found within a line) is considered a comment and therefore ignored. #
127.0.0.1 localhost
192.168.0.11 snu.lge.com
192.168.0.11 rdvs.alljoyn.org
192.168.0.11 fi.lgtvsdp.com
192.168.0.11 us.lgtvsdp.com
192.168.0.11 in.lgtvsdp.com
192.168.0.11 IN.lgtvsdp.com
192.168.0.11 GB.lgtvsdp.com
a. Copy all and overwrite with AcrylicHosts.txt file content
4. Run downgrade process follow my tutorial
5. If all goes well, remember to restore DNS settings on TV and then you can check for OTA updates...
1. Download
<MSG>Success</MSG>
<IMAGE_URL>
<CDN_URL>
# found at:                                          #
# should write:                                                             #
127.0.0.1 localhost
Hi Simon,
First of all, thanks a lot for still helping us. I believe that we will be able to downgrade our dumb TVs very soon with your help, but please don't give up on us :)
I have tried your above solution, exactly following the steps as you described but unfortunately my "in_dump.txt" file is still empty and my TV does not find any updates yet again. Here is the updated log from the "startDNS.bat" command window:
C:\LgDTVUpDater>cd dns
C:\LgDTVUpDater\dns>AcrylicConsole.exe
2015-10-27 23:51:49.984 TBootstrapper.StartSystem: Loading configuration file...
2015-10-27 23:51:49.984 TBootstrapper.StartSystem: Loading address cache items...
2015-10-27 23:51:49.999 TBootstrapper.StartSystem: Loading hosts cache items...
2015-10-27 23:51:49.999 TBootstrapper.StartSystem: Starting resolver...
2015-10-27 23:52:06.720 TResolver.Execute: Request  ID 59492 received from client 192.168.2.146:49736 regarding "lgtvonline.lge.com" of type A.
2015-10-27 23:52:06.735 TResolver.Execute: Response ID 59492 sent to client 192.168.2.146:49736 directly from address cache.
2015-10-27 23:52:06.940 TResolver.Execute: Request  ID 06602 received from client 192.168.2.146:33316 regarding "TR.lgrecommends.lgappstv.com" of type A.
2015-10-27 23:52:06.940 TResolver.Execute: Response ID 06602 sent to client 192.168.2.146:33316 directly from address cache.
2015-10-27 23:52:06.940 TResolver.Execute: Request  ID 50041 received from client 192.168.2.146:33316 regarding "TR.lgrecommends.lgappstv.com" of type AAAA.
2015-10-27 23:52:06.959 TResolver.Execute: Response ID 50041 sent to client 192.168.2.146:33316 directly from address cache.
2015-10-27 23:52:07.194 TResolver.Execute: Request  ID 06883 received from client 192.168.2.146:33316 regarding "wbivqgfopgom" of type A.
2015-10-27 23:52:07.194 TResolver.Execute: Request  ID 06883 forwarded to server 8.8.8.8:53.
2015-10-27 23:52:07.209 TResolver.Execute: Request  ID 06883 forwarded to server 208.67.220.220:53.
2015-10-27 23:52:07.209 TResolver.Execute: Request  ID 43137 received from client 192.168.2.146:33316 regarding "rznmgybqqxhfnql" of type A.
2015-10-27 23:52:07.209 TResolver.Execute: Request  ID 43137 forwarded to server 8.8.8.8:53.
2015-10-27 23:52:07.209 TResolver.Execute: Request  ID 43137 forwarded to server 208.67.220.220:53.
2015-10-27 23:52:07.209 TResolver.Execute: Request  ID 26562 received from client 192.168.2.146:33316 regarding "qfknzhnt" of type A.
2015-10-27 23:52:07.225 TResolver.Execute: Request  ID 26562 forwarded to server 8.8.8.8:53.
2015-10-27 23:52:07.225 TResolver.Execute: Request  ID 26562 forwarded to server 208.67.220.220:53.
2015-10-27 23:52:07.278 TResolver.Execute: Response ID 43137 received from server 208.67.220.220:53.
2015-10-27 23:52:07.278 TResolver.Execute: Response ID 43137 sent to client 192.168.2.146:33316 and put into the address cache as negative.
2015-10-27 23:52:07.278 TResolver.Execute: Response ID 06883 received from server 8.8.8.8:53.
2015-10-27 23:52:07.294 TResolver.Execute: Response ID 06883 sent to client 192.168.2.146:33316 and put into the address cache as negative.
2015-10-27 23:52:07.294 TResolver.Execute: Response ID 26562 received from server 8.8.8.8:53.
2015-10-27 23:52:07.309 TResolver.Execute: Response ID 26562 sent to client 192.168.2.146:33316 and put into the address cache as negative.
2015-10-27 23:52:07.309 TResolver.Execute: Request  ID 60902 received from client 192.168.2.146:33316 regarding "rznmgybqqxhfnql" of type A.
2015-10-27 23:52:07.325 TResolver.Execute: Response ID 60902 sent to client 192.168.2.146:33316 directly from address cache.
2015-10-27 23:52:07.325 TResolver.Execute: Response ID 06883 received from server 208.67.220.220:53.
2015-10-27 23:52:07.325 TResolver.Execute: Response ID 06883 discarded because no session cache entry matched.
2015-10-27 23:52:07.341 TResolver.Execute: Response ID 43137 received from server 8.8.8.8:53.
2015-10-27 23:52:07.341 TResolver.Execute: Response ID 43137 discarded because no session cache entry matched.
2015-10-27 23:52:07.341 TResolver.Execute: Request  ID 56635 received from client 192.168.2.146:33316 regarding "wbivqgfopgom" of type A.
2015-10-27 23:52:07.359 TResolver.Execute: Response ID 56635 sent to client 192.168.2.146:33316 directly from address cache.
2015-10-27 23:52:07.363 TResolver.Execute: Response ID 26562 received from server 208.67.220.220:53.
2015-10-27 23:52:07.363 TResolver.Execute: Response ID 26562 discarded because no session cache entry matched.
2015-10-27 23:52:07.363 TResolver.Execute: Request  ID 02266 received from client 192.168.2.146:33316 regarding "qfknzhnt" of type A.
2015-10-27 23:52:07.378 TResolver.Execute: Response ID 02266 sent to client 192.168.2.146:33316 directly from address cache.
2015-10-27 23:52:12.547 TResolver.Execute: Request  ID 52057 received from client 192.168.2.146:33316 regarding "snu.lge.com" of type A.
2015-10-27 23:52:12.547 TResolver.Execute: Response ID 52057 sent to client 192.168.2.146:33316 directly from hosts cache.
2015-10-27 23:52:12.563 TResolver.Execute: Request  ID 10132 received from client 192.168.2.146:33316 regarding "snu.lge.com" of type AAAA.
2015-10-27 23:52:12.563 TResolver.Execute: Response ID 10132 sent to client 192.168.2.146:33316 directly from hosts cache.
2015-10-27 23:52:17.567 TResolver.Execute: Request  ID 18328 received from client 192.168.2.146:33316 regarding "snu.lge.com" of type AAAA.
2015-10-27 23:52:17.583 TResolver.Execute: Response ID 18328 sent to client 192.168.2.146:33316 directly from hosts cache.
2015-10-27 23:52:25.589 TResolver.Execute: Request  ID 52660 received from client 192.168.2.146:33316 regarding "snu.lge.com" of type AAAA.
2015-10-27 23:52:25.589 TResolver.Execute: Response ID 52660 sent to client 192.168.2.146:33316 directly from hosts cache.
P.S. I will also try the same procedure on that old Windows XP laptop I have mentioned earlier and let you know about the result in the upcoming days (I am currently using Windows 10 Home Insider Preview Build 10565 and although I disable my firewalls maybe there might be some additional security settings blocking the computer-TV network connection, that is why I always mention that Windows XP machine and want to try the procedure on that too :) ).
Hello again Simon,
I also tried the above solution on that Windows XP machine but once again the process has failed ("in_dump.txt" file is still empty and my TV does not find any updates) with the following log on the "startDNS.bat" command window:
2015-10-28 13:20:34.125 TBootstrapper.StartSystem: Loading configuration file...
2015-10-28 13:20:34.125 TBootstrapper.StartSystem: Loading address cache items..
2015-10-28 13:20:34.125 TBootstrapper.StartSystem: Loading hosts cache items...
2015-10-28 13:20:34.125 TBootstrapper.StartSystem: Starting resolver...
2015-10-28 13:20:40.171 TResolver.Execute: Request  ID 36536 received from clien
t 192.168.2.146:55470 regarding "lgtvonline.lge.com" of type A.
2015-10-28 13:20:40.171 TResolver.Execute: Response ID 36536 sent to client 192.
168.2.146:55470 directly from address cache.
2015-10-28 13:20:40.375 TResolver.Execute: Request  ID 43198 received from clien
t 192.168.2.146:57763 regarding "TR.lgrecommends.lgappstv.com" of type AAAA.
2015-10-28 13:20:40.375 TResolver.Execute: Response ID 43198 sent to client 192.
168.2.146:57763 directly from address cache.
2015-10-28 13:20:40.640 TResolver.Execute: Request  ID 22150 received from clien
t 192.168.2.146:57763 regarding "zgngrfcmun" of type A.
2015-10-28 13:20:40.640 TResolver.Execute: Request  ID 22150 forwarded to server
 8.8.8.8:53.
 208.67.220.220:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
2015-10-28 13:20:40.656 TResolver.Execute: Request  ID 35535 received from clien
t 192.168.2.146:57763 regarding "tkkspwq" of type A.
2015-10-28 13:20:40.656 TResolver.Execute: Request  ID 35535 forwarded to server
 8.8.8.8:53.
 208.67.220.220:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
2015-10-28 13:20:40.656 TResolver.Execute: Request  ID 22105 received from clien
t 192.168.2.146:57763 regarding "kdxrhsdkvuluxhz" of type A.
2015-10-28 13:20:40.656 TResolver.Execute: Request  ID 22105 forwarded to server
 8.8.8.8:53.
 208.67.220.220:53.
 0.0.0.0:53.
2015-10-28 13:20:40.671 TResolver.Execute: Request  ID 22105 forwarded to server
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
2015-10-28 13:20:40.703 TResolver.Execute: Response ID 22150 received from serve
r 8.8.8.8:53.
2015-10-28 13:20:40.703 TResolver.Execute: Response ID 22150 sent to client 192.
168.2.146:57763 and put into the address cache as negative.
2015-10-28 13:20:40.718 TResolver.Execute: Request  ID 13056 received from clien
2015-10-28 13:20:40.718 TResolver.Execute: Response ID 13056 sent to client 192.
2015-10-28 13:20:40.718 TResolver.Execute: Response ID 35535 received from serve
r 8.8.8.8:53.
2015-10-28 13:20:40.734 TResolver.Execute: Response ID 35535 sent to client 192.
2015-10-28 13:20:40.734 TResolver.Execute: Response ID 35535 received from serve
2015-10-28 13:20:40.734 TResolver.Execute: Response ID 35535 discarded because n
2015-10-28 13:20:40.734 TResolver.Execute: Request  ID 60078 received from clien
2015-10-28 13:20:40.734 TResolver.Execute: Response ID 60078 sent to client 192.
2015-10-28 13:20:40.750 TResolver.Execute: Response ID 22105 received from serve
r 8.8.8.8:53.
2015-10-28 13:20:40.750 TResolver.Execute: Response ID 22105 sent to client 192.
2015-10-28 13:20:40.750 TResolver.Execute: Request  ID 55608 received from clien
2015-10-28 13:20:40.750 TResolver.Execute: Response ID 55608 sent to client 192.
2015-10-28 13:20:40.843 TResolver.Execute: Response ID 22150 received from serve
2015-10-28 13:20:40.843 TResolver.Execute: Response ID 22150 discarded because n
2015-10-28 13:20:40.875 TResolver.Execute: Response ID 22105 received from serve
2015-10-28 13:20:40.875 TResolver.Execute: Response ID 22105 discarded because n
2015-10-28 13:20:49.984 TResolver.Execute: Request  ID 55834 received from clien
t 192.168.2.146:57763 regarding "snu.lge.com" of type A.
2015-10-28 13:20:49.984 TResolver.Execute: Response ID 55834 sent to client 192.
168.2.146:57763 directly from hosts cache.
2015-10-28 13:20:49.984 TResolver.Execute: Request  ID 53004 received from clien
t 192.168.2.146:57763 regarding "snu.lge.com" of type AAAA.
2015-10-28 13:20:49.984 TResolver.Execute: Response ID 53004 sent to client 192.
2015-10-28 13:20:50.671 TResolver.Execute: Request  ID 62754 received from clien
t 192.168.2.146:57763 regarding "safebrowsing.google.com" of type A.
2015-10-28 13:20:50.671 TResolver.Execute: Request  ID 62754 forwarded to server
 8.8.8.8:53.
 208.67.220.220:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
2015-10-28 13:20:50.687 TResolver.Execute: Request  ID 62754 forwarded to server
 0.0.0.0:53.
2015-10-28 13:20:50.687 TResolver.Execute: Response ID 62754 received from serve
r 8.8.8.8:53.
2015-10-28 13:20:50.687 TResolver.Execute: Response ID 62754 sent to client 192.
168.2.146:57763 and put into the address cache as positive.
2015-10-28 13:20:50.718 TResolver.Execute: Response ID 62754 received from serve
2015-10-28 13:20:50.718 TResolver.Execute: Response ID 62754 discarded because n
2015-10-28 13:20:50.921 TResolver.Execute: Request  ID 56787 received from clien
t 192.168.2.146:57763 regarding "safebrowsing-cache.google.com" of type A.
2015-10-28 13:20:50.921 TResolver.Execute: Request  ID 56787 forwarded to server
 8.8.8.8:53.
 208.67.220.220:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
2015-10-28 13:20:50.937 TResolver.Execute: Response ID 56787 received from serve
r 8.8.8.8:53.
2015-10-28 13:20:50.937 TResolver.Execute: Response ID 56787 sent to client 192.
2015-10-28 13:20:50.968 TResolver.Execute: Response ID 56787 received from serve
2015-10-28 13:20:50.968 TResolver.Execute: Response ID 56787 discarded because n
2015-10-28 13:20:53.984 TResolver.Execute: Request  ID 40409 received from clien
2015-10-28 13:20:54.000 TResolver.Execute: Response ID 40409 sent to client 192.
2015-10-28 13:21:02.000 TResolver.Execute: Request  ID 59105 received from clien
2015-10-28 13:21:02.000 TResolver.Execute: Response ID 59105 sent to client 192.
2015-10-28 13:21:16.015 TResolver.Execute: Request  ID 03239 received from clien
2015-10-28 13:21:16.015 TResolver.Execute: Response ID 03239 sent to client 192.
2015-10-28 13:21:59.468 TResolver.Execute: Request  ID 15427 received from clien
t 192.168.2.146:57763 regarding "www.youtube.com" of type A.
2015-10-28 13:22:01.937 TResolver.Execute: Request  ID 15427 forwarded to server
 8.8.8.8:53.
 208.67.220.220:53.
 0.0.0.0:53.
 0.0.0.0:53.
2015-10-28 13:22:01.953 TResolver.Execute: Request  ID 15427 forwarded to server
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
2015-10-28 13:22:01.953 TResolver.Execute: Request  ID 10792 received from clien
t 192.168.2.146:57763 regarding "www.youtube.com" of type AAAA.
2015-10-28 13:22:01.953 TResolver.Execute: Request  ID 10792 forwarded to server
 8.8.8.8:53.
 208.67.220.220:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
2015-10-28 13:22:01.968 TResolver.Execute: Request  ID 10792 forwarded to server
 0.0.0.0:53.
 0.0.0.0:53.
 0.0.0.0:53.
2015-10-28 13:22:01.968 TResolver.Execute: Response ID 15427 received from serve
r 8.8.8.8:53.
2015-10-28 13:22:01.968 TResolver.Execute: Response ID 15427 sent to client 192.
2015-10-28 13:22:01.968 TResolver.Execute: Response ID 10792 received from serve
r 8.8.8.8:53.
2015-10-28 13:22:01.968 TResolver.Execute: Response ID 10792 sent to client 192.
2015-10-28 13:22:02.000 TResolver.Execute: Response ID 15427 received from serve
2015-10-28 13:22:02.000 TResolver.Execute: Response ID 15427 discarded because n
2015-10-28 13:22:02.015 TResolver.Execute: Response ID 10792 received from serve
2015-10-28 13:22:02.015 TResolver.Execute: Response ID 10792 discarded because n
mtuna10, please check this shit with other network. I'm getting really pissed off.
Hi Simon,
I didn't really understand what you mean with the other network? I have tried this method with two different laptops on ethernet, is that what you mean?
Hey mtuna10,
I mean, maybe your Internet is the source of the problem. Maybe configuration of the Internet, or something like that. I've tried dozens of times get such situations with my TV, and nothing. I really don't know how to make in_dump file has not been overwritten. If something can be updated, it is also possible that this will outdated. But not in the case of your TVs. It's really annoying, though in general I am a very patient man.  B)
i hope somebody can help me here to downgrade my lg32ld750.
I have the same problem as mtuna10.
in_dump.txt and apache log stays empty.
My TV has firmware version 04.00.01 now. But latest firmware on lg page is 03.21.03.
I also tried the "option and press fav 7 times" method but sadly this gives an unknown error message.
Is there some other method to downgrade?
Thanks!
One more thing... DNS settings in laptop or router. Do you have automatic settings? I'm not sure if it's relevant, but in Acrylic log I see Google DNS IP 8.8.8.8 and OpenDNS IP 208.67.220.220.
Hello shm0,
Stay tuned, we will continue to attempt to resolve this problem.
Updated:
I checked your TV - it's not equipped with webOS. It's an old TV 2010/2011. LGwebOS forum is dedicated to devices with webOS, so I'm sorry, but I'm afraid that I will not be able to help you, the more that personally I don't have the right knowledge at this moment. Anyway I'll look around a little bit. If I find something, I'll let you know in a private message.
Hey mtuna10,
 Yes Simon, it's really strange, I do not understand what I am doing wrong  :wacko:
Yes, I have automatic DNS settings; I will change it to 8.8.8.8 or OpenDNS IP and try again.
Also, I have another modem, I will try the same procedure with that modem. Also, I will set my TV to factory settings before the procedure; I do not know what I am going to do if this fails too :) I will let you know about the results.
No, it is rather not do anything. I thought that you might have set up one of these IP addresses. Automatic settings seems to be a good choice.
I thought also about another modem and reset settings, but I'm afraid some of your health.  ;)  In the worst case we both go crazy, and maybe dtosun also be joining us.  :D
Seems like there is no way to downgrade. The Update locked the debug mode and bootloader. Maybe through rs232 connection.
Thanks anyway!
Well, resetting the TV settings to factory defaults did not work either Simon  :(
I will also try again with my old modem tomorrow and I hope that we will be able to maintain our mental health at the end  :)
i'm still also with you guys :)   (Simon, i really appreciate your kind patience. thanks a lot!)
i have tried all possible ways too but still negative. One of the ways that i haven't tried is make an ethernet wired connection between PC and TV without router since i don't know how to do. And the last one of the ways is to learn russian to make our TV hacked by russian guys... :D
my last reply, fyi:
I've tried your last update but still no changes in in_dump file. I perform the work by WiFi network.
- I set the area code for Russia as suggested by @mbabakj
- turned off windows 8.1 firewall (no antivirus soft.)
- checked for port 80 for apache.exe (also, AcrylicConsole.exe uses port 53)
- checked the gateaway if both pc and tv match (192.168.1.1)
Note:
Our Turkish UF8507 model number is different from Russia UF850V model. May this cause the problem?
It's great hepmisafir, even more lunatics.  :D
I remember your post, but I forgot to answer. Sorry about that. Anyway, you see what is the situation with your UF850x. And I don't think so that different model number may cause downgrade problem. All the time I think the problem is in the wrong configuration of the connection between TV, PC and Internet/LG servers. If we are unable to connect to LG servers, wired connection between PC and TV without router will not help us. I also thought about it, the problem is only in fact that for me everything is working properly, so I can't see how it works for you.
you are probably right. Some guys argue interesting problems/solutions about similiar issues on this page:
we hope to find a working solution. otherwise we will be cracked by the warranty terms. And i'm afraid we will not get new official update for a few years.  :rolleyes:
