Issue with Info button after update
By OliverRC
By Ajothen
By Roy Brown
By atcronin
Matjaz
Info button on the remote is not working after expected after upgrading to 5.00.04.
Previously first press on Info button showed a short summary for current program. Second press showed larger info window where you could scroll the text. Third press closed Info panel.
After update Info only toggles information panel on/off. When info window contains more information than it fits on screen, I see scroll-bar on right, but there is no way to scroll. Pressing up/down shows info for different programs and left/right shows previous/next program.
Am I missing something?
I know there are other ways to see full program description by clicking on Programme icon, I just think there should be a way to scroll in Info pane if they show the scroll-bar.
