I was told yesterday by Lg that the Webos 2.0 firmware was coming out that day. I have tried several times to manually do it through the tv and no luck. The web site still shows the old version also. Has anyone got the update on the 65UB9200? Thanks.
    • By SHawk
    • By Sqwazy
    • By majorusa
      - 3.23.24 - Romania- 47LB730v
    • By сергей фролов
    • By SailorMoon
