Hi everyone.
I've recently bought a LG smart TV. I'm French but I like to enjoy movies and series in their original audio version. It's not easy to change the audio while watching a movie with this OS. You have to go through the parameters each time. That's why I've changed the main audio language to Original Version and the second to English.
But now every time I watch television, the subtitles pop up. This happens each time I change channel. I have to press ont he "subtitle" button of the remote twice: once to activate the subtitles (yes I have to even though they are already here) so that I can remove them pressing it the second time.
That's not a big problem but it is really annoying. Do you know anything about it?
For me who like to change languages very often that OS is really badly designed. I used to have a normal LG TV and that was way easier to  switch between audio channels.
Thanks for helping!
    • By MURAD
    • By dzoole
      Silly question by me, but it seems that I can't find subtitle button on LG ThinQ app on my mobile phone? Anyone knows if we can select subtitles through the LG ThinQ app?
    • By BGee
      On my LG 60SJ850T, Watching Horizon from AppleTV streaming service. Western with some scenes with Apache language being spoken. No subtitles appearing. When CC is on, see “foreign language being spoken”. When viewed on iPhone, there are subtitles. Have tried same movie using chrome cast TV, and casting from iPhone to Apple TV device. Never get subtitles. Verified subtitles work when I stream to same chromecast TV connected to a different TV.
      reset LG TV to factory settings after trying all available CC and subtitle settings on TV. Still no subtitles.
    • By Danster75
      Hi all,
      I'm Danny and have a problem with my LG OLED65C8;
      since a few months when playing movies, either from my Syno NAS or just plain USB, subtitles are being displayed double (over or above eachother) or are displayed for sometimes minutes after the sentence's been spoken. The videofiles haven't got any hardcoded subs but either subs included in the mkv container or as separate srt of ssa file. Disabling subs removes the display of subs, enabling subs results in double or persistent subs.
      Subtitles have been disabled in the accessability menu, factory reset did not help.
      I searched but as far as I can see this problem has not been discussed yet, also googled and never came across this problem. Perhaps someone here can help?
      Kind regards, Danny
      SOLUTION, for me at least:
      I used ColorControl to reboot the TV. It's weird that a factory reset did not work but a simple reboot did.
    • By dzoole
      Can you add opaque box for subtitlws when we warch from smart share, external hdd etc... so practicly in thw subtitle menu choose for opaque box and transparency. Thanks in advance
