New Firmware 5.00.04 Broke my TV!!!!
By OliverRC
By SHawk
By Sqwazy
By majorusa
- 3.23.24 - Romania- 47LB730v
By сергей фролов
Pioneer123
My TV has just automatically installed the new firmware rev 5.00.04 and now the HDMI connection is dropping out every 5-10 minutes to my AV amp. It never did this before and it basically makes the TV unwatchable.
I have even changed the AV amp to verify its the TV and it still does it. A factory reset hasn't fixed it either.
My TV is a 79" 79UB980T and I am in Singapore.
Anyone have any suggestions for a cure?
Cheers
7 answers to this question
