Is their anyway to mirror my iPhone 6 to lg WEBOS tv other than the hdmi lighting cable ?
I mean app like miracast in android phones
Sent from my iPhone using Tapatalk
You can use
on your Mac or PC connected to TV, or if you just want to watch videos, pictures and listen to music, try , etc. for iOS.
  • 2 months later...
  • 3 months later...
The only program I know you can directly "stream" to an LG TV is Youtube IOS app. When you're playing a video in your phone, if this phone is in the same network as your TV, then Youtube should be able to detect the TV and a sharing option should show up in the app where you can select your LG tv. Probably some other apps should include that option, I think youtube is using the so-called ConnectSDK, not sure: http://www.lgwebos.com/topic/1456-lg-releases-connect-sdk/
  • 3 months later...
