Was the WebOS 2 update pulled?
By OliverRC
By Ajothen
By Roy Brown
By Batman
By Khelben Arunsun
neblap
When LG released the WebOS 2 update my TV updated itself. Unfortunately my TV then developed the AV2 popup problem and was taken away by LG to replace the main board
Upon the return of my TV it was running an old firmware which I updated and is now 04.45.25
Searching for a later firmware returns "Unable to check for updates."
I rang LG customer support who advised that I download the update direct from their website, but the only listed firmware is 04.45.25.
Their only other advice was that the TV had to get used to the update before it can update to a later firmware, and that was from a supposedly Technical Support agent.
Has LG withdrawn the update? Or is "Unable to check for updates" a problem?
My TV's model number is 47LB650V-ZN
