3D Subtitle (.sub, .idx, .ssa ) (.ass) is working 2D !!!
Hello Every body
I Have Only One Issue with my Smart TV 47LB6520 (with Smart-share App in my TV)
when i play from my USB (connected directly)  3D Move with 3D Subtitle File I'm already tested it on My Laptop is Not Working on my LG Smart TV .
Only one File working with .SRT File is .ASS but working in 2D View  ???!!
any body know about this issue ?? how can i fix it ??
Many Thanks for your Support :)
TV Model : 47 LB6520-TB
Software Version : 5.00.04
    • By Rex G
    • By sudar shan
    • By NaveenKumar
    • By jcol5786
