aymag108 Posted October 26, 2015 Posted October 26, 2015 I've just updated my LG TV software to version 05.00.15 and the subtitles are no longer available, any idea how to fix it? Sent from my SM-N910U using Tapatalk Quote
abttuf Posted October 29, 2015 Posted October 29, 2015 1) Play your movie 2) When you see Strange characters appears with your subtitles hit Pause. 3) In the Pause menu click on the little arrow on the right hand side. 4) Click on the button that says 'Sub' 5) Click on External 6) A hidden menu will Appear!!! 7) Select Code Page that suit your languge till the Subtitle characters appeares fine 8) Also you can select Size, Color, Position, Sync....etc Quote
rbarca Posted October 29, 2015 Posted October 29, 2015 hi, i think a buy LG 42lb7200 model tv, can i update this webos 2.0? Quote
SIMON Posted October 29, 2015 Posted October 29, 2015 hi, i think a buy LG 42lb7200 model tv, can i update this webos 2.0? Hi rbarca, It is not possible to upgrade webOS 1.x to webOS 2.0. And you'd better think carefully, if at all you have to buy LG. Please read forum before. There are many problems with webOS 1.x and also 2.0. If you need a TV to watch movies and television, you'll be pleased. But if you need a good Smart TV, do not do this, because Smart TV by LG = fucking shitty Dumb TV. Don't waste your money. It's better to wait a bit and buy something else, otherwise you will spend many days on this forum... Quote
Bartosz Górski Posted November 11, 2015 Posted November 11, 2015 thank you simonLook for TV sets with android TV. Philips and Sony has something in offer. LG is noy Worth itWysłane z mojego XT1068 przy użyciu Tapatalka 1 Quote
SIMON Posted November 11, 2015 Posted November 11, 2015 Look for TV sets with android TV. Philips and Sony has something in offer. LG is noy Worth it Definitely better choice is SONY BRAVIA Android TV. Philips and its firmware is shit worse than LG. Sent from my iPhone using Tapatalk Quote
Jai Posted November 14, 2015 Posted November 14, 2015 If not my 7 yrs old tv goes white screen suddenly last year, I would wait for Sony android tv. Sony has been losing market share I am also not very sure how committed Sony is going to ensure profit to sustain the cost maintaining it. Wish Sony success. Sent from my Sony Xperia Z1 using Tapatalk Quote
