Hi all.....
again I am a samsung TV user for many years, but this time I desicded to try LG, I bought LG 65UF950T TV from the Dubai, UAE, but when I wanted to download Netflix, ITV Iplayer and BBC Iplayer, I couldnt, I tried to change the location but locations availabel are Africa and Middle East. I did factory rest but no luck. Any idea how can I change the location to some where in Europe or USA please. I am very disappointed with this TV.
There's another site that has instructions on how to change the location. If you have a phone/tablet with IR you can download the app from the android playstore and it will allow you to change the location...just make sure you write down the original..here is the link on how to do it...I bought the tv in Germany and I was able to download apps from the US...if u :
Thanks KingP1n for your reply
I have read the link you mentioned, but is there other solution that doesn't require buying expensive equipment that I don't really need (harmony remote control).
Just make sure what version you use it has an IR blaster built in (note 5, s4,s6 edge and samsung tablets have them etc). Download app it's a few $ ...open app and and go into the service menu...follow instructions on other link for correct code to use in order to enter the service menu....go into location and write down the original number for your location. Now change the location to US or whatever country you want...turn tv off...go into settings and find location. Here it's gng to ask you to input a zip code...I used a random zip from the states (i.e. 22132). Now the lg store sld populate and you must go into the premium apps. You also might need to create another lg account in order to access premium apps. If you use USA as location you can download pandora..iheartradio. ..Netflix etc....
Thanks again KingP1n, I will ask around and see if I can get a friend with android and fellow your instructions. Will let you know in few days. Thanks again
  • 2 weeks later...
No not yet, still looking for android mobile phone, no one I know has one, all iPhones, as soon as I get one I will let you know.
Thanks KingP1n for asking again
  • 1 month later...
KingP1n, at last I found a friend who has Samsung mobile and I download the app and it worked, thanks for your help.
Now I changed the region to UK, wanted to download Skype but couldn't, it's not in the LG content store/Premium/apps and games, do you know how can I download load Skype. Thanks
I haven't changed my location to US in awhile but I know for sure the European location has Skype in the premium apps....I have my current location to Spain and just looked in there and it does show skype for download....I'm not sure if the US location removed it but you may try the Europe location and see if it works....let me know...
I'm not sure what's gng on...but i think LG removed the Skype app temporarily. ...I say try again and a few weeks....did u create a new account once u switched location?
    • By jcol5786
      LG’s Better Life for All vision encompasses every aspect of life, emphasizing sustainable living and raising educational standards for children in rural areas. In line with this commitment, LG offices around the world actively participate in local initiatives aimed at improving the lives of the people and communities they engage with daily.
      To commemorate World Cleanup Day (September 20) and International Coastal Cleanup Day (September 21), LG Singapore organized its first-ever beach cleanup event at East Coast Park in conjunction with local green social enterprise
      link hidden, please login to view.
      As part of the brand’s sustainability efforts, this initiative sought to highlight the importance of taking action against Singapore’s growing marine plastic pollution problem while promoting the 3Rs – Reduce, Reuse and Recycle – when dealing with used packaging.
      By combining the company’s eco-conscious innovations with a community-driven effort, LG Singapore hopes this initiative will help foster a culture of environmental consciousness within consumers.
      With the much-appreciated help of Green Nudge, over 100 LG Singapore employees collected 293 kilograms of trash – mainly plastic packaging, bottles and Styrofoam – from three sites across Singapore’s eastern coastline, which was then carefully processed for proper disposal.
      To foster camaraderie among employees, LG Singapore organized eager volunteers into teams and promised an award to the group that collected the most trash. The winning team, which collected a total of 104 kilograms of trash in just one hour, received a small token of appreciation from Gerald Chun, managing director of LG Singapore.
      The success of the beach cleanup highlights LG’s dedication to environmental stewardship and community involvement, with the revitalized beach serving as a powerful reminder of the impact collective action can have. LG Singapore looks forward to promoting sustainability in more exciting ways and inspiring others to join its mission to preserve nature.
      Moving on to another vibrant part of Asia, in the spirit of Life’s Good, LG Taiwan hosted an event in September to inject positive change into the local community. Since 2009, LG Taiwan has been deeply committed to improving the standards of education in the nation’s rural areas, working alongside third-party organizations and public welfare institutions to inspire warmth and hope. This long-standing dedication was recently demonstrated through a collaboration with the Feng Chia University School of Architecture.
      This involved LG Taiwan assisting Feng Chia University’s Book Hut Project to create an impactful after-school learning space for children living in the countryside. First, LG donated smart home appliances to meet their daily needs, with the local children taking an immediate liking to the LG TV’s advanced voice control features and its sheer size. LG also donated two washing machines that make everyday laundry easy and convenient, requiring only the press of the power and start buttons to operate.
      Under the leadership of Jeong Yeon-kwan, managing director of LG Taiwan, a team of 23 LG employees joined student volunteers from Feng Chia University in Hualien to transform a building into an inspirational learning environment with a new lick of paint and various decorations.
      In addition to getting hands-on in Hualien, LG Taiwan donated home appliances to the rural Nantou and Taitung regions to spread the power of education. Managing director Jeong showed teachers and children how each appliance works to ensure they received the full benefits. And to add a personal touch to their visit, LG volunteers prepared Korean snack packs for the children and student volunteers.
      To support the transformation of its local community, LG East Africa collaborated with Korea Food for the Hungry International (KFHI) to complete two local projects. These initiatives – in Kajiado County and Nairobi’s Huruma slums – were the winning entries of the 2024 LG Ambassador Challenge. Each received KES 1 million in funding to make an impact on local communities.
      As a part of the first initiative in Kajiado County, LG East Africa took part in transforming Intinyika Primary School. The school, which has 180 students, was equipped with essential infrastructure, including a solar power system, water storage facilities and computers. These upgrades address critical needs, such as electricity, water and educational resources, significantly improving the learning environment for local students. LG is hopeful that the new equipment will benefit and improve the lives of local students, with the new computers enabling them to learn more about digital technologies in a more comfortable learning environment.
      In Nairobi’s Huruma slums, LG East Africa provided aid to the Furaha Community Foundation to improve their physiotherapy center, which treats more than 30 children with disabilities. With the funds from the LG Ambassador Challenge, the center acquired essential equipment, including gym tools, to provide effective care and treatment.
      Now in its fourth year, the LG Ambassador Challenge is part of LG East Africa’s social responsibility initiatives. The program aims to recognize and support groups that actively address pressing challenges within their communities. The 2024 edition saw 53 applications, with the winning projects standing out for their potential to create lasting change. To ensure the sustainability of these projects, KFHI will continue to provide customized monitoring and support. This includes regular visits, communication and oversight to maximize the impact and facilitate meaningful change within the communities.
      LG will continue to arrange various activities around the globe to spread its Life’s Good brand promise. To learn more about LG’s local initiatives around the world, visit .
      Contributed by LG Singapore, LG Taiwan and LG Kenya
    • By Ramya Shyam
    • By glendvd100
      Hi there, I have the following tvs:
      OLED55C26LD
      OLED42C24LA
      And I'm trying to change the area code using the service remote, so I can download apps from USA (I'm currently in the UK), such as Max, HULU etc.  I'm trying the codes which are bandied around the internet, but the area just stays as EU.  I've noticed on youtube videos etc that the older models with the older OS have no issued with this, but mine seems unable to change.
      Does anyone know if perhaps the newer models have newer codes?  I've used 1793, 1843 and 22287 (as found in this very forum).  But nothing happens.  Any help from users who may have got this working would be appreciated, thank you.
    • By Jim11787
      New OLED C3. New setup and I can’t change channels using tv magic remote- I have to use set top box remote. Verified setup with LG tech today and it is correct. Upon him checking for solutions he said there is a software bug that is not allowing the magic remote to change channels. Stated a fix is in works but doesn’t know when it will be available. Asked for a supervisor and was told one would call back in a few hours but they didn’t. I can return the tv now but was wondering if others are having this issue and for how long. I don’t want to get stuck with a tv with multiple remotes.
