YouTube App
By Lee Magee
By Will M
By David Joseph
By Владимир Морозов
By JonoW
Halli
I've just got the LG 55EG920v and trying to get to grips with webOs 2.0. I'm looking for 4K content and was surprised that the YouTube App wasn't pre-installed and doesn't seem to be available via the LG content store.
Am I doing something wrong or is there an alternative way yo access YouTube?
Halli. (UK)
