[Help]49uf850v Firmware update
Good morning,I'm new in this forum.
A few days ago I bought an LG tv uf852v, after the configuration wizard my tv update itself at firmware 3.3.55 but I saw that on LG webpage support there is a new update released on September 3.20.5 but my tv don't see it. Does Anyone know how?
Thanks a lot.
Inviato dal mio LG-D802 utilizzando Tapatalk
You need to do a manual firmware update as per LG instructions here:
I had the same problem updated to 03.20.05 manually. Basically download the zip file un-zip it and drop the file in a folder called 'LG_DTV' on a USB stick. Plug it in and switch the TV on. It should then update.
Once you've updated you should get an automatic update to 04.00.40.
    • By PVD
    • By mean2
    • By JRay
