Netflix won't work on an LG 55EG920V TV set
By Horniak
By CJ Catalano
By JRay
By P.T.
I have a LG G3 Oled Tv 65 inch. I want to record Tv programs using the correct USB HDD . Could some one out there give me some specifics of a USB HDD that will work on my TV .
Peter
frederic.cudeiro
Hello!
I'm experiencing big trouble with the Netflix app and I begin to lose patience. Some help would be much appreciated!
Before first use, the TV said an update was required. LG Content Store also claimed v.1.3.76 (24/11/2015) was available.
Thus, I updated, signed in and everything worked fine: I could play anything I wanted to, including 4K content, without any trouble.
In the evening, Iput the TV in stand by mode and the next day when I tried to use the Netflix app again, it was saying "We're having trouble playing this title right now. Please try gain or select a different title." with ALL the titles, while Internet web browsing and YouTube worked perfectly fine.
I tried to reload the app: it didn't work.
I tried to exit (using the 'exit' function in the app) and start again the app: it didn't work.
I tried to sign out and sign in again: it didn't work.
I tried to restart my internet box: it didn't work.
I tried to unplug the TV for a few minutes: it worked, but it got exactly the same issue the next time I put the TV in stand by mode. Plus, it doesn't work all the time.
I tried to reset the TV to factory default, reset everything, re-update the app: it worked, but once again the issue reappear every time I put the TV in stand by mode.
I tried to go to 'My page' to check if I could remove the app to reinstall it completely, but it seems I can't.
Netflix customer service was no help, LG's no help either.
Any idea?
Many thanks in advance.
Fred
Details:
TV software version: 03.01.25
TV country set to France (where I live).
Netflix app version: 1.3.69 according to the Netflix app settings menu...while the LG Content Store claims 1.3.76..strange!
TV connected to my internet box through Ethernet
Cable internet provider (tested 100/5Mbps from one of my MacBook Pro)
Everything works fine on my PS4, my two MacBooks Pro and my smartphone.
Sent from my Nexus 6 using Tapatalk
