How ti installo silverlight for watching skygo
By Batman
Serial Number:- 309MAUAGGP74
Programme Mode:- Antenna
Software Version:- 23.21.30
By Charlie F
Charlie
By Eliasking
Hello
on hdmi port 1 2 3
when i watch a grey screen through youtube and through the apple tv or ps5 i get this weird discolor bottom half
only happens when hdr is on and vivid mode on lg c3
on hdmi port 4
this issue doesnt happen
on native youtube its fine no issue
By Fergus
When I try to get Netflix on my LG Smart TV I get a message saying that Netflix ended support for Silverlight on 13 September 2023 and I needed to update the browser to a version that supports HTML5. It said that normally this should update automatically, but if it did not that is why I am seeing that page.
The browser is Google Chrome so I tried to update that - but nothing happened - I did check I was connected to wifi. So then I tried to install Microsoft Edge which was shown as an option, then I got the message " File Downloading is not Supported" and nothing happened, which probably also explains why Chrome failed to update.
I see from other posts that WebOS does not support Android Apps - so how can I reinstate Netflix on my LG Smart TV?
Thankyou
By bucksears
I bought a new LG 43uq7590pub (43" 4K UHD) TV three months ago, with the intent of using it as a computer monitor.
Configuration is as follows:
Running it in Gaming Mode Computer is set for 4K resolution (3840 x 2160) Connected via HDMI cable to my computer (don't have the cable stats in front of me) Computer's video card is set to a 60Hz refresh rate When watching streaming videos from the local computer (YouTube, MAX, Netflix, etc), the TV will randomly go black and restart. There is no warning (audio/video slowdowns or distortions/glitches) before it does so. After restarting, it continues to run normally. Anything over 30-45min and it will likely restart.
I'm not using wifi/internet locally on the TV, so that is not (or shouldn't be) the issue.
I'm wondering if running the computer's video AND audio over the HDMI cable is too much for the TV, and that's causing the restarts after a while. I have a separate MIDI/audio interface that I usually run the computer's audio OUT of, to a pair of external speakers. This is a whole new computer setup, so I don't have that in place yet; just wondering if taking that workload OFF of the TV/HDMI might help.
Are there any event logs within the TV OS that might indicate what is happening?
Anyone else experience anything similar?
