Degradation of picture quality with newer 05.00 firmware on LM670
I noticed severe degradation of picture quality with newer firmware. What are they doing? Picture is not sharp any more, but when you increase sharpness option it becomes even worse - unwacthable.
Did anybody alse noticed it? I am talkin about good sources- bluray remuxes.
    • By SHawk
    • By Sqwazy
    • By majorusa
      - 3.23.24 - Romania- 47LB730v
      Key Specifications:
    • By Low Grade
      many thanks in advance😃
