By Lorenz
By wallyricks
By akhil7j
Designed for Ultimate Gaming Immersion, the New GX7 Features
Advanced WOLED Technology and Cutting-Edge Connectivity
SEOUL, Nov. 18, 2024 — LG Electronics (LG) is unveiling its latest, premium UltraGear OLED gaming monitor GX7 (model 27GX790A). Designed for serious gamers, the new model features a 27-inch, QHD resolution (2,560 x 1,440) WOLED display with a 0.03milliseconds Gray-to-Gray (GTG) response time and a 480Hz refresh rate – the fastest of any QHD OLED monitor. The 27GX790A, the most compact UltraGear OLED display yet, delivers enhanced gaming immersion with exceptional picture quality, silky-smooth performance and 4-side virtually borderless design. It also works seamlessly with the newest graphics cards, thanks to an array of advanced connectivity options, including DisplayPort 2.1.
The all-new 27GX790A is equipped with LG’s WOLED display technology, which employs a white OLED light source with color filters to produce accurate RGB colors and impressive screen brightness. This technology provides a high contrast ratio, vibrant colors, deep blacks and excellent motion clarity – even during the most fast-paced gaming action – LG’s WOLED tech has earned the new UltraGear OLED gaming monitor both VESA DisplayHDR True Black 400 certification and highest VESA ClearMR tier.
Additionally, the 27GX790A offers NVIDIA G-SYNC® compatibility and AMD FreeSync Premium Pro support, further enhancing the gaming experience by eliminating distracting screen-tearing and flickering. The application of LG’s Anti-Glare & Low Reflection (AGLR) Coating provides a more comfortable gaming experience in brighter rooms, enabling gamers to see what’s happening on screen without difficulty.
Incorporating DisplayPort 2.1 and HDMI 2.1 interfaces, the 27-inch UltraGear OLED gaming monitor ensures compatibility with the latest consoles and gaming PCs, as well as next-generation GPUs expected to launch in early 2025. DisplayPort 2.1 yields a 67 percent increase in bandwidth compared to DisplayPort 1.4, meaning it can support higher resolutions and refresh rates.
Contributing to a cleaner gaming setup, the monitor’s slim, flat L-shaped stand lets users place their keyboard on top of its base and offers ergonomic comfort and customizability with a swivel range of -30 to 30 degrees. It also comes with a 4-pole headphone jack to allow convenient in-game communications via headset and supports DTS Headphone:X. DTS’s three-dimensional audio solution for headphones provides accurate sound positioning, helping users pinpoint where noises are coming from – which can mean the difference between victory and defeat in intense FPS or online battle royale games.
“An ideal choice for serious gamers, the 27GX790A boasts a 27-inch OLED screen with an exceptionally fast 480Hz refresh rate,” said YS Lee, vice president and head of the IT business unit of LG Business Solutions Company. “Our new UltraGear OLED gaming monitor is perfect for both console and PC gaming, offering a range of connectivity options and compatibility with the latest gaming hardware. The LG UltraGear brand will continue to provide high-performance monitors that enhance every aspect of the gaming experience.”
Specifications:
LG UltraGear OLED Gaming Monitor GX7 (27GX790A)
Display Type WOLED (Anti-Glare & Low Reflection (AGLR))
Screen Size 27-inch Design 4-side Virtually Borderless Design Resolution 2,560 x 1,440 Color Gamut DCI-P3 98.5% Refresh Rate (Max.) 480Hz Response Time 0.03ms GTG HDR VESA DisplayHDR True Black 400 Highest VESA ClearMR tier
Adaptive Sync NVIDIA G-SYNC® Compatible AMD Free-Sync Premium Pro
Connectivity HDMI 2.1 x2 DisplayPort 2.1 x1
USB3.0 1up 2down
4-pole headphone out (DTS Headphone:X)
Stand Tilt (-5° to +15°) Swivel (-30° to + 30°)
Pivot
Height (110 mm)
Wall Mountable (100 mm x 100 mm)
At Frieze London 2024, LG OLED and Akomfrah Bring Art and Technology
Together to Inspire Audiences With a Thought-Provoking Film Installation
SEOUL, Oct. 11, 2024 — LG Electronics (LG) has once again partnered with the widely respected artist and filmmaker, Sir John Akomfrah, for Frieze London 2024. This collaboration follows LG’s recent support of Akomfrah’s British Pavilion at the 60th International Art Exhibition at La Biennale di Venezia 2024. At Frieze London 2024, LG OLED has invited Akomfrah – an artist and filmmaker known for investigating themes such as memory, post-colonialism, temporality and aesthetics – to present a new video installation at the fair.
Becoming Wind (2023) is a five-channel video installation that focuses on the intersection of social and environmental issues, looking specifically at the experience of non-binary and trans actors and activists in the context of the climate crisis. A profound meditation on identity formation is framed by an allegorical representation of the Garden of Eden and its disappearance; a montage of footage evoking the abundant richness of past biodiversity is interrupted by glimpses of blazing wildfires, scenes of racial discrimination and a fragmented text, underscoring responsibilities to confront multiple and intersecting crises.
Powered by the compelling fusion of art and technology, multiple ultra-large LG OLED displays bring Akomfrah’s artistic narratives to life with stunning picture quality on an incredible scale. Notably, LG OLED’s self-lit nature reveals the full, vivid expression of the colors, enriching the depth and realism of the artwork’s multi-sensory elements for a truly immersive experience.
LG’s commitment to making LG OLED a more sustainable choice closely aligns with Akomfrah’s drive to address climate change, human communities and the plight of migrant diasporas globally. LG OLED TVs incorporate fewer components than LCD TVs due to the absence of a backlight, which results in the 65-inch OLED TV using 60 percent less plastic compared to an LCD TV of the same size. Weighing in at about 20 percent less than an LCD TV of the same screen size, OLED screens also contribute to the reduction of CO2 emissions during transit. In addition, recycled plastic accounts for approximately 20 percent of the plastic used in the manufacturing of all LG TVs, including OLED models. These efforts have culminated in LG OLED TVs receiving environmental product certifications from the UK’s Carbon Trust and Switzerland’s SGS for four consecutive years, underscoring the company’s commitment to sustainability.*
“I’m truly delighted to be able to bring my artistic vision to life with LG OLED,” said Akomfrah. “Becoming Wind aims to draw viewers into a deep state of contemplation about the intrinsic relationship between nature, humanity and technology through the interplay between sound and visuals. LG OLED’s advanced audiovisual capabilities and technological advancements enhance the sensory elements of the art, seamlessly integrating image, sound and emotion to take audiences on a visually compelling and intellectually stimulating journey.”
“We are pleased to continue our collaboration with renowned artist Sir John Akomfrah to highlight how LG OLED captivates audiences by enhancing the depth of his thought-provoking artwork,” said Kate Oh, vice president of the Brand Communication Division at LG Home Entertainment Company. “LG OLED remains committed to supporting both artists and audiences who embrace our passion for innovation and positive change. We will continue to empower artists who seek to inspire the world through the intersection of art and technology.
Visitors to Frieze London 2024 can experience Akomfrah’s artwork Becoming Wind from October 9 to 13 at The Regent’s Park. Visit the
link hidden, please login to view to step into a world of artistic brilliance and explore captivating collaborations with LG OLED ART. # # #
* Carbon Trust: Carbon Footprint Reducing certifications (2024 LG OLED evo G4 77”/65”/55”)
Carbon Footprint Measured certifications (2024 LG OLED evo G4 97”/83”, C4)
SGS: Environmentally Evaluated certifications (2024 LG OLED evo G4/C4/B4)
- 1 answer
- 2,103 views
- 1 answer
- 10,602 views
- 6,264 views
- 2,282 views
Rajeev
I am having an updated WebOS for my LG 55" UHD SMART TV. I am having problem with my Media Library refresh. The SmartShare app on the TV keeps showing all the Videos/Movies which no longer exist on my network. When I use Device Connector however, and select only the Plex Media then I see the available Movies correctly.
How to refresh or clear the Media Library on the TV... any help will be appreciated.
Thanks.
Rajeev.
3 answers to this question
