How to watch HBO GO on a non supported TV
By Evelynn
I am trying to access Livenettv through my LG smart TV however I keep getting the downloading not supported when wanting to download V4.7 apk file. Please can you advise?
By Rizwan Sumra
By matesz
PS2. I've heard that Denon AVR-X3600H works but this is massive overkill for what i need (i don't indend to go beyond stereo, not even 2+1).
By dolbnya
- 3 answers
- 4,425 views
- 0 replies
- 4,087 views
- 3 answers
- 4,223 views
- 0 replies
- 4,780 views
Leo Gsx
Is there a way to watch HBO GO on a non supported LG TV. My model is 47LB650V and is not listed in the supported TVs on HBO GO website.
