40UF770V-ZB external HDD problem or user problem?
Hello everybody,
I hope somebody has already crossed the same problem and can get me out of this.
When I connect a 1TB HDD on any of my 3 USB slots, it will create a LG Smart TV file on it. So far so good.
When I try to record, it only shows 196MB available and therefore refuses the recording due to unsufficient space, as at least 40GB are required.
Any idea what I am doing wrong, or what I could try? My HDD is a 1TB Toshiba USB 3.0 disk.
Many thanks in advance
The answer was pretty simple: the TV does not supply enough power through the USB slots to support recent performing hhd's. After I connected a hdd with external power supply the problem was gone.
    • By Hasan Ghasabi-Oskoei
      Can you help?
    • By PVD
    • By hollean
    • By AJO
    • By mycop
      Greetings.
