Netflix App for India
By Nicola123
By Ramya Shyam
By JackYU
FIFA World Cup 2022 is exclusively going to stream on Jio cinema app in India but app is missing from web os content store. Pls add it asap. The app is available on Android TV
By Cash
Have LG OLED 55B36LB bought in 2023 in UK.
Trying to change area option from 3122 (EU-UK) to 4816 (AJ-India) using a service remote.
It does not update or change.
any help for guidance will appreciated.
By svsrama
Sriram.
Satinder85
Just wanted to know since Netflix has been launched in india. When will Netflix app will be launched in india.
