Bootloop after update software
55la6210 smart tv software update and now jusr shows logo then off repeatedly.
Flashed new program but still same. The eeprom has three partitions it seems :
Flash 524288 kb
Dram 524288 kb
NVM 128 kb
Is in repair centre but they and LG don't know how to fix.
Anyone with experience of this, it is 2013 model.
    • By OliverRC
    • By Ajothen
    • By atcronin
    • By Batman
