Hope someone can help please.
I have 79" UHD LG TV which has my Home Theatre amp (Anthem MRX510) connected to HDMI 3 to provide 4K content from my Mac Mini using Plex.
I have recently signed up for Netflix and want to use the amp to rebroadcast the sound but when I switched on ARC it just killed the sound altogether. So a few questions first.
1. When Netflix is running which HDMI port would the sound come from?
2. Has anyone had any luck making ARC work with other equipment?
3. Would I be better switching to another HDMI channel to run Netflix and have a cable connected from the designated HDMI channel to the 2nd Monitor output of the amp (both outputs support ARC)?
    • By Nicola123
    • By svsrama
      Sriram.
    • By cptl
      Any thoughts?
    • By Sandtonman
      Dolby Vision is 22.11.
    • By Edgar Corona
      I have a 55" smartv, i'm having problems with Netflix app, anyone knows why, i can't open de app, everything after and update send it by the tv..
